Question about Microsoft Xbox 360 Console
When i turn on my xbox 360 it had green in the middle and red flashing around. Can you tell me what is wrong whith that? thank you...
    President:
  • Microsoft Master
  • 1,623 Answers
It can mean numerous things check this link http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on Mar 19, 2011
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on, i have 3 red lights,i know this is the ring of death but when the power brick is on it should be a green light but turns orange after about 2 seconds, the three red lights are...
Hi honyimhome,
there is only one way i know of correcting this situation.
as weird as it sounds
you need to overheat the xbox 360 in order to get it working correctly again. i know this as i have one myself and been in the same situation.
you need to switch the console on then wrap a towel around it and leave it for approx 30mins.
this should return it to its correct working order.
Hope this has helped :)
Sep 26, 2009 | Microsoft Premium System for Xbox 360
Red light flashing and will not work.
if that happens make sure all the connections in the back of your xbox 360 are connected and if it is still flashing red its probably the red ring of death and thats were three rings are flashing red so if its like that your going to have to send your xbxo 360 into microsoft
Jul 06, 2009 | Microsoft Xbox 360 Console
Two red and green lights around the on button?
http://ezinearticles.com/?What-Do-Xbox-360-Red-and-Green-Lights-Mean?&id=1981493
Jun 15, 2009 | Microsoft Xbox 360 Console
Flashing Green Light
your xbox might be downloading a game that you ask to download or some other type of media. to chick turn it on and go to active downloads and see.
Feb 09, 2009 | Microsoft Xbox 360 Console
My xbox 360 has three red rings and one green in the middle
the 3 red rings are the worst and there is no way to fix it, i tried wrapping a towel around it and leaving it for an hour or so and that worked for me... the is a good old xbox remidee, but if that dosnt work then call the hot line and you will have to send it off.. the usually have it back in about a week
thanks, max
Dec 15, 2008 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
Xbox 360 not turning on, just red flash
It seems the power supply of your console has gone bad. Kindly have a local cartified technician check your Xbox ASAP.
Apr 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
