Question about Panasonic NN-S255 Microwave Oven
The oven is not heating the food - Panasonic NN-S255 Microwave Oven
  • Panasonic Master
  • 6,993 Answers
Investigate these three areas if your microwave won't heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Good luck.
Posted on Mar 19, 2011
How do I fix the oven when it no longer heats food but all other features of the oven work fine?
Could be a burnt out fuse but most likely its the heating coil is burnt out.
Sep 01, 2015 | GE Microwave Ovens
Tip
Difference between a convection oven and a conventional oven
<span>A convection oven is equipped with a fan to speed the circulation of heat around the food, thus cooking it faster and more evenly than conventional ovens. <br /><br />Conventional ovens rely on radiant heat that rises from the bottom up to the top of the oven. Convection ovens cook foods approximately 25% faster than conventional ovens, and the oven temperature can be reduced by 25&deg;F for most foods. <br /><br />No special cookware is required. Just like conventional ovens, convection ovens can be gas- or electrically-heated. As with any major appliance, it is always best to carefully read the manufacturer's guidelines and instructions for operating the oven.</span>
on Apr 04, 2011 | Microwave Ovens
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Oven does not heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | Sharp R-1480 Microwave Oven
EMO3000 1000 Watts Microwave Oven: Doesn't heat food...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
7sttus
May 17, 2010 | GE EMO3000 Microwave Oven
Microwave not heating any food
Basic Microwave Oven TroubleshootingTips
heatman101-0=-0
May 10, 2010 | Maytag MMV4205 Microwave Oven
Regarding microwave
Sanjay
This is due to the magnatron failing (this is the part of oven that cooks the food!) This is the most likely cause of y isssour oven not heating the food!
Magnatron needs replaced for oven to work again!
Please rate this free soultion!
Jan 18, 2009 | Sharp R-308J Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Panasonic NN-S255 Microwave Oven Logo
134 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
