Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
My Dell 1800FP monitor is dead. There are no lights and no image on the screen when plugged in. I replaced the power module already and checked it with another known good power supply but no luck. What do I check next?
  • Jeffrey DiMarzio Mar 19, 2011
    I already replaced the entire power module (which includes this chip) and tested the new one in a working monitor. I need to know what the next most likely problem would be.
    Thanks
  • 2,574 Answers
Replace IC 901 (ICE2AS01)
ICE2AS01 is available at this link.
Posted on Mar 19, 2011
  • Reparatii PC - Service IT
    The next you need to check is the inverter board.
    it can be found at this link
LED light is and screen is black
Check the switch mode power supply IC for shorts. This is very common problem for this model, you can get the repair kit for it on EBAY.
Replacement power supply module: http://www.lcdrepair.us/1800fp-power.html
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 29, 2011 | Dell 1800FP Monitor
Video on 1800FP flashes on and off.
You need to check the output voltage of the power supply module to see if the 12vdc output is swtiching on and off, it can be power supply failure or it is sensing short circuits, it can also be the inverter board.
http://www.lcdrepair.us/1800inverterKUBNKM045A.html
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 12, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
May lcd monitor dell not power
If there is no power or "Led" indicator on the power button, try plugging the power cable to a different power point. If still won't turn-on, try changing the power cable. If still no power. It only means the LCD is already deffective.
Hope this helps.
Mar 28, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My Dell 1800FP monitor went black
Confirm your cables did not work themselves loose. Try using a different power cable to confirm that it was not the cable. Finally try a lamp in the socket you are using for the monitor power cable, if you are not using a power bar but even then just to rule that out. If the only thing left is that your monitor is dead, you will need to recycle that one and purchase yourself another one. Sorry
Sep 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
1800FP Dell Monitor Light continuously blinks no picture
I have made a solution to this and it can be found on my website here:
http://www.dorchestercomputerrepairs.com/1800.html
Hope this helps.
sparkyuiop
Sep 28, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP is black on start up but green light is on
i had the same problem i found out it was the inverter i replaced it and it was like new. i do have 2 inverters if you are intrested
Jul 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Computer monitor
try making sure that the power wire has a good clean connection and is securley plugged into your outlet. also try using a different cable like the power cable to your pc. if it still isnt turning on. you will need to take it to a repair shop or replace it.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP, green power light, black screen....
Its probably the inverter that lights up the screen that went bad.I have replaced inverter before with much sucess. If you feel comfortable opening the unit up I found one on ebay. Here is the link.
http://cgi.ebay.com/1800FP-LM181E06-FPD1830-18-LCD-Inverter-KUBNKM045A_W0QQitemZ300179625342QQihZ020QQcategoryZ74936QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Dec 09, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
94 people viewed this question
Alun Cox
