Question about Yamaha Audio Players & Recorders
I have yamaha rav312 remote but its volume buttons are not working rest of them are working fine. i cleaned it from in side but result is still same.
    Brigadier General:
  • 8,546 Answers
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description
Posted on Mar 19, 2011
How to clean inside of YAMAHA VS71410 remote?
Check the remote control for its infrared emission. Check it with fresh batteries.If you wish to get more details about how to check and clean a remote control, please visit this site.One among the posts has details about it.Surf the site with patience.
Aug 03, 2014 | Yamaha Remote Control RX-V390 p/n:VS714100
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
The volume buttons don't work well at all. You have to push the buttons so hard to get it to work 20% of the time. I have new batteries. Other buttons work fine, just the volume buttons are the...
The first thing I would look at is the battery's some times they are not worn out but just need to be wiggled to clean the contact points. if that doesn't fix it you may need to switch to a universal remote. I Good luck.
Feb 22, 2011 | Yamaha RAV-250 Remote Control
Hi There I do have a Yamaha Remote Control Rav312 that no longer work. I am thinking about buying a new one but can't find anywhere. However I saw a Remote Control Rav311 which looks almost exactly the...
i better suggest that you buy a universal remote that supports Rav312 rather than buying a Rav311, coz sometyms there are instances that even they look exactly the same the programs of each buttons are different unless they have the same chipboard. So, to play safe go for a universal remote that supports Rav312. hope that it helps.
Feb 16, 2011 | Yamaha Audio Players & Recorders
I have a yamaha rav312 remote but i dont have the manual can i get the codes and programming info for panasonic tv's ?
i hav yamaha rav312 remote but its volume buttons are not working rest of all are working fine. i cleaned it from inside but result is still same.
Dec 12, 2010 | Audio Players & Recorders
Open the case of the remote to clean contacts
This maintenance procedure will not accomplish the desired result.
Sep 27, 2017 | Audio Players & Recorders
My RAV 250 remote for my HTR 5740 has button issues.
if you can open the remote try cleaning the board this will help make the contact
the other way to test remote is a camra on phone
turn on camra and press the buttons and if you see a flashing light then that button ok try the rest
Nov 28, 2009 | Televison & Video
After working fine, remote wont work properly. sometimes works, but not always; volume control suddenly does not work
Try opening your remote and clean the side of the pcb that the rubber buttons rest on with a q tip containing acetone or methylated spirit.
Aug 17, 2009 | Samsung TV Remote Control
846 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
