Question about Briggs & Stratton Garden
Installed new starter rope on 3.5 briggs and stratton mower and when you pull rope to start, rope does not recoil
  • 927 Answers
The spring must be tightened when installing the cord:
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Posted on Mar 19, 2011
Can i take the pull starter off my briggs and stratton mower in one unit
Yes you can... if you are removing the center screw and wanna take the whole rope pulley off, do it slow... if when you start pulling off the pulley and you feel like the recoil is coming up with it, immediately put it back down or the recoil spring will unravel fast... it's not impossible to ravel the spring back up, just a pain if you have never done it before. If you are trying to install new rope, you can do so without removing the pulley at all.
Go to you tube and you will find multiple videos on how to replace rope on lawnmower recoil assy
Tons of videos. You can do this!! Good luck
Oct 11, 2015 | Garden
Can i take the the pull starter off my briggs and stratton mower without dismantlng the spring
Tons of videos. You can do this!!!!! Good luck!
Recoil rope on my briggs and stratton lawnmower will only pull out a few inches
One of many causes, have you tipped the mower on its side recently? is there oil in the engine( has engine seized? has the rope got wrapped around starter cup?
Apr 01, 2015 | Garden
I have a 3hp briggs & stratton//the pull rope pulls freely//it does not engage the engine and turn the engine over
You probably need to replace the starter recoil. This is not a very expensive fix. Just be aware that this problem is usually caused by having to pull the starter rope excessively because of some other starting problem. Once you replace the recoil, keep your engine running properly.
Sep 07, 2014 | Garden
How do you start a biggs stratton 450 series rotorvator
Usually the 450 series only a recoil starter....a pull rope to start it. Meaning you have to pull the starter rope to start it.
Apr 28, 2014 | Briggs & Stratton Garden
I start twice (when I pull starter rope) then the rope won't go back can I know what happen
Your starter/recoil unit has malfunctioned. Disassembly/inspection down to the point where you can get the recoil off will be required. Remove the engine cover screws. The recoil unit may be part of the cover or may be under it. You will easily be able to access it. Replacement parts for your mower are readily available.
Apr 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
How do I repair the pull cord on a masport 600 mower - the cord snapped when I was trying to start it.
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assy. Depending on engine model you may hae to remove the air shroud with the recoil.
- Remove the broken rope assy from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rop burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end of the trheaded through rope.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assy.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Briggs & Stratton Briggs Stratton...
Broken starter cord on briggs and stratton quantum 40 roughly 1994 how to repair
Remove the recoil. Sometimes depending up on model this required complete air shroud removal. Remove the parts of the old rope. Remove the rope fro the rope handle. NOTE the knot in the handle. Brun both ends of the nylon rope with a match and pinch the burned end into as small of circumference as possible. Install new rope into the starter handle and tie the knot. Pull the new rope into the handle until it seats securely.
Prewind the recoil pulley as far as you can easily wind it. Back it off (unwind) just until the rope guide and pulley knot hole are aligned. Then either c-clamp it in place with the rope knot hole aligned with the rope guide hole or have a 2nd person hold it the pretensioned spring and pulley in position. Thread the rope through the rope guide and on into the pulley knot hole. (takes some effort to get it aligned and through the knot hole!) Pull the new rope through the knot hole and tie 1 knot. Pull starter rope and fit knot into pulley knot hole. Release pulley C-clamp or have helper let go of pulley. Rope should rewind into the recoil.
Reinstall recoil / air shroud. Happy mowing!
Thanks for choosing FixYa.
Kelly
Nov 20, 2010 | Briggs & Stratton Garden
Garden Logo
153 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
