Question about Ovens
We just bought and installed a second hand GE wall oven in nearly new condition. Could we please get an owner's manual?
  • 449 Answers
Http://www.geappliances.com/service_and_support/literature/
Posted on Mar 18, 2011
Looking for an Owner's Manual for a GE Electric Single Wall Oven Model # JKP2OBOF3BB.
I do not see the JKP2OBOF3BB among the GE appliances. The manual for the JKP2OBFBB 27" Single Wall Oven is available here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-80475.PDF . Most GE appliance manuals can be found by searching here: http://www.geappliances.com/service_and_support/literature/ .
I hope this helps.
Mar 26, 2011 | Ovens
GE wall oven was in self clean mode and suddenly an F2 error keeps beeping. It also flashes looked door - please help
Those are error codes which are listed in your owners manual. If you do not have the manual go to the GE web site, customer support section.
Mar 06, 2011 | GE Ovens
Touch panel dosent work... only used 5 times
if the touch panel is not working as in at all its mostly likely defective and seeing how you have only used the unit 5 times wouldnt this be considered pretty much as new if it is new then it would be also warrantied which means you wouldnt have to pay for it on the other hand if you bought the machine 2nd hand then here is the entire schematic for your wall oven
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Wall-oven-Parts/Model-ZET938WM1WW/0432/0125300?searchedModel=ZET938&blt=
also check to assure that you dont have a button that is stuck pushed in any case you would most likely need to call a technician so he can diferentiate between which piece is defective it would be either part number 16 which is the oven control or part number 1 or it could even be part number 997 is not connected properly or has came loose which i have seen due to some delivery people many times heres the diagram for the control section showing these part numbers http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fG0903127-00001.png if you have any further questions message me back and please message me back with the questions i asked about. Also please remember when our chat is through to rank how this opinion has helped it allows me to help others in the future Thanks Rick
Feb 01, 2011 | GE Monogram® ZET938 Electric Single...
How to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
Need wiring diagram for part number WB27T10276 for ge oven model JRS04BW3BB
For anyone installing a replacement oven controller #WB27T10276, there is a GE publication # 31-10515 that should answer your questions. I bought a rebuilt control that did not have this info. with it. Lucky for me, a retail appliance parts store opened a box with a new control in it and copied the instructions for me.
Aug 14, 2010 | GE 24" Built-in Single Electric Wall Oven...
We bought a maytag electric over built in type, and not to sure if it is a 110 or 220 amps / volts also need information to hook it in
Open the door and look inside near the base of the door. It will say the voltage. Ours is 110. You can go to the maytag website to get an owners manual and installation manual for free.
Nov 27, 2009 | Maytag 24" Built-In Single Electric Wall...
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
F4
luvin, F4 is a shorted oven sensor. Under 950 ohms. Should read 1060 ohms at room temp. The sensor is located in the upper left hand corner of the rear oven wall. Remove the 2 screws and it will pull out enough to remove the connector. Catriver.
Aug 22, 2007 | GE JKS05 Electric Single Oven
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
