Question about Fisher and Paykel GWL11 Top Load Washer
Hi there, I have a MW059NZ Smart Drive 9 Pride washer that has decided to stop working. Turn machine on (lights up ok) press start but nothing happens. Then a friend said to press power button and advance together, panel lite up like a xmas tree (flashing through the panel of lights) turned it of and on, now I get a beeb beeb beeb when i press start?? I get the feeling I shouldn't have listened to my mate!! Please help help Kind Regards Grant
    Prodigy:
    An expert who has answered 500 questions.
  • Fisher and P... Expert
  • 510 Answers
Under the top of the machine on the right there is a reed switch which is actic=vated by a magnet in the lid remove the two bungs and screws so you can lift the top up a bit and you will see it there one screw to remove it if its corroded or swollen its faulty either repace it or as a easy fix cut both wires off it and join them together and tape up, this should do it
Posted on Apr 21, 2018
  • 1294 Answers
SOURCE: F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Posted on Feb 08, 2008
  • 1294 Answers
SOURCE: fisher & Paykel Smart Drive 9 Pride
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Mar 13, 2008
SOURCE: F&P Smart drive 9
I have the same problem but it has both hot and cold water setup and has done for years. This problem occurs on any setting; size, temp, speed. no luck here either
Posted on Jun 19, 2008
ngfam1
  • 639 Answers
SOURCE: model GW609NZ f&p washing machine/smart drive 6.5kg excellence
Dear herman worth and Guest also!,
ngfam1 here for you!
I am happy to be of assistance!
FIX IT NOW BEFORE IT GETS WORSE AND COST MORE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Pleas egive me a good rating here in fixya.com before you sign out!
Posted on Aug 26, 2008
SOURCE: Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Posted on Sep 15, 2008
Cold water not pulling into Fisher & Paykel 5.5kg Smart Drive Pride.
Either the cold water inlet solenoid has failed or there is a fault with the electronic control module, Unfortunately the only way to find out is to replace the cold water solenoid and see if it works, if it doesn't then the electronic control board is faulty.
Mar 16, 2017 | Fisher Washing Machines
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
I have a Frigidaire Pride Smart Drive top loader washing machine and I would like to give the bowl and inside where the powder goes in, a jolly good clean. How do I go about this? I'm worried that...
hi i have a fridgedair pride 5.5 wen i turn my washing machine on theirs know water going into the machine the water keeps going stop go stop go how can i fix the problem every thing else is fine.
May 26, 2011 | Fisher and Paykel Washing Machines
Ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fault code 37,what does indicate.
Hi just read your posting.This error code is called PUMP BLOCK ERROR.Now please look under the machine for me to the front right.You should see a red or black fan,This is your pump.Now turn the fan clockwise and anticlockwise a few times to loosen it up if it is jammed.The fan should turn freely.Now put the machine back on its feet and select a spin cycle.The machine should start to drain.Please reply to tell me how you got on or if it still does not drain or if you have the other type of pump.Good luck
Jul 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our Fisher and Paykel 603 smart drive has stopped
most likely your problem is your lid switch visit your local spare parts dealer and purchase a new one
Feb 06, 2010 | Fisher Washing Machines
Fisher and paykel Smart Drive 9, pride 5.5 turns on by itself and beeps
Probably a bad controller. Note the lights that are illuminated and call F/P.
Jul 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Jan 17, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
82 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
