Question about Xerox WorkCentre M123 Copier
Fuji xerox document centre C250
Hi guys i've brought a second hand copier model fuji xerox document centre c250 ..but there seems to be a previous owner setting and pwd... how can i reset it to factory setting again?
  • Anonymous Aug 25, 2008
    we not have printer driver for document centre c250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Posted on Sep 04, 2008
    Scholar:
  • 53 Answers
Sorry, what do you mean by "setting and pwd?"
Posted on Aug 20, 2008
Fuji xerox document centre 350 manual to download?
The User's Guide for the Document Centre 350 is available from the product support page. There are two files (one for the scanner and one for the printer). See http://onlinesupport.fujixerox.com/processDriverForm.do?ctry_code=TW&lang_code=en&d_lang=en&corp_pid=DC350&rts=null&model=Document+Centre+350&type_id=5&oslist=Windows+95&lang_list=en and the Documentation tab. The drivers are available for supported OS versions on the Drivers tab.
I hope this helps.
Jun 27, 2013 | Office Equipment & Supplies
KONICA BIZHUB C250 DOCUMENT FEEDER PRINTING ON ANGLE
Clean the feeder paper feed,separator roller with cloth and alcohol.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
Drivers for Xerox C250
Hi, if you click on the below link -
Xerox C250
it will take you to Fuji Xerox driver download page, just select your operating system and langauge, click go and it will take you to the correct driver you need to download.
Thanks, if this solution helps please rate :)
Feb 21, 2011 | Computers & Internet
Hi, new installation of a C250, we can recieve faxes but cannot send faxes is there a special fax setup that is required please help thanks Mal
You have to enter the tools area of the machine, then enter the phone number and a name ID to make the Fax work.
Normally you press access, the user name will be admin and the password is either 1111 or 11111.
Then find fax settings and enter your fax phone number and an account name. Your name or you business name. That will make it work.
Feb 21, 2011 | Xerox Document Centre 332 Copier
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is...
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Regards
M-PRESS.BIZ
Feb 09, 2011 | Konica Minolta bizhub C250 All-In-One...
Hi, My glass is broken on my Konica Minolta Bizhub 250, could I get a ballpark figure to replace it? Looking forward to hearing from you. Regards, Michelle
Hi Michelle,
The Original Glass for a C250 would be around £100. This is my best guesstimate as I don't have the price list to hand. For some reason all copier manufacturers charge a fortune for the glass.
We have a C250 Original Glass which in currently fitted to a C250 in our warehouse. I doubt the machine will ever be repaired, we've taken circuit boads from it to support our field machines.
If you're in the UK and interested, I'm guessing you could have it for around £35 ?
Regards
m-press.biz
Jan 18, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Cannot scan documents on Konica C250/C250P
Hi, If it is set up as a network printer, then go to administrator settings & check the IP address of the machine.
Jan 16, 2008 | Konica Minolta bizhub C250 All-In-One...
SERVICE ERROR CODE
I am trying to find what that code means. If you want to look for yourself, there are tons of C250 manuals at the following link at Minolta.
http://kmbs.konicaminolta.us/content/support/supporthome.html
Pick category: Office systems
Pick model: C250
Jan 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Xerox WorkCentre M123 Copier Logo
3,581 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
