Question about ASUS M2N-MX Motherboard
CPU not support found !!
I put a new processor in, and everything worked fine. It suggested that I update the BIOS version. I updated to the latest and restarted, now when I start it says: "CPU not support found !! System will shut down after 15 seconds."
I figured it out! Only took me 5 hours :P. What I had to do was actually DOWNgrade my bios to 0804 instead of 1004. I don't know why, but it did not like that latest version.
Posted on Aug 03, 2008
  • 781 Answers
You need to change settings in your bios for the type of cpu you changed to
Or reset your bios to default it could still be set up for old cpu
Posted on Aug 02, 2008
Problem upgrading CPU
Try to update the BIOS with the old CPU in, if not the new CPU could be faulty, yes I know it's new but it is entirely possible
Apr 19, 2014 | eMachines W3619 PC Desktop
Compatibility of Athlon CPU and ASUS Motherboard
Yes it will work just fine. Just download and update your Bios to the latest version which is the 1007 release and you should be good to go. You can get the latest Bios here:
http://dlcdnet.asus.com/pub/ASUS/mb/socka/sis741GX/A7S8XMX07.zip
Jul 12, 2012 | Computers & Internet
Hi.I have a ASUS M2N68-AM SE2 Motherboard with AMD Athlon 64 X2 6000+ Processor.Whenever I boot,it says that the CPU is not supported.I have updated my BIOS to the latest version.Still doesn't help...The...
What bios are you using? Usually that error message can be disregarded since you can manually set the CPU clock, voltage, etc in the bios and it should work. Also, this might mean that the bios currently loaded is corrupted/broke. But since you did update the bios, to what version?
Also, are you using the integrated graphics for gaming? If so, that would not suffice for heavy gaming at high resolution. You should be using a dedicated video card for that.
As for system performance, how slow is it? What is your OS as well? can you try to download cpuid, and see if your processor is detected properly in windows.
Apr 27, 2011 | ASUS M2N68-AM SE2 Motherboard
I have a HP/Compaq TC4400 tablet pc. I recently had to replace the motherboard and now have a problem with booting. I get the following message: The following configuration change was requested to this...
there are two way either you set the password in system bios or reformat the hard drive and reinstall the operating system . it will fix all the seeting to new motherboard.
Nov 21, 2009 | Compaq tc4400 Tablet PC
Put a e7400 2.93 cpu will start bios but no keyboard what other processor will fit.its a asus p5kc motherboard
Try reflashing your bios with latest version check usb is enabled in BIOS if your using a usb keyboard otherwise maybe a dodgy board. Good luck
Aug 01, 2009 | ASUS AiLifestyle P5KC Motherboard
I swithed to asus crosshair motherboard. put in an athlon 6400 x2. Connected everything right. When i turn the power on, it stays on for just like 7 seconds then turn off. at the back the lcd says comp...
HAVE YOU CHECKED TO SEE IF MOTHERBOARD SUPPORTS THAT EXACT CPU.OR YOU MAY NEED TO CHANGE A SETTING(S) IN THE BIOS.TRY NOT USING AUTO DETECT FOR CPU MANUALLY ENTER INFO.RICHARDM69
Dec 02, 2008 | ASUS CROSSHAIR Motherboard
Upgrading CPU not booting BIOS
Key Features
Form Factor Micro ATX
Compatibility PC
Chipset Intel 865GV
Compatible Processors Intel Pentium 4
Front Side Bus Speed 800 MHz
Technical Features
Integrated Input/Output Ports USB 1.1 x 4 • Serial Port x 1 • RJ45 Lan Port x 1 • PS/2 Mouse x 1 • PS/2 Keyboard x 1 • Parallel Port (ECP/EPP/SPP) x 1 • Floppy Port x 1
Expansion Slots PCI x 3
Storage Controller Type(s) Serial ATA x 2, DMA/ATA-100 (Ultra) x 2
South Bridge Chip Intel ICH5
Processor
Socket Type Socket 478
Max supported CPUs qty 1
Memory
Number of Memory Slots 4 x DIMMs
Supported RAM speeds 400 MHz
Max Supported RAM 4 GB
so this is the board..no doubt that the cpu fits and is a good choice for you.
however,if the old one works fine and this one ,even if it is new,does not wiork,the only rational conclusion is that this one is malfunctioning ,maybe from the factory,or maybe one of the pins doesnt make a real contact.
check very attentive the integrity of the pins and of the cpu socket in the motherboard.
there are also some cases that the motherboard doesnt support the high Frequence of the new processor,but that was a problem for the old PCs..I doubt you have it with your motherboard.
I suggest you to bring it back and to ask for a replacement,or at least go with it to  a specialised cervice and let them check it.
sorry for not beeing a huge help to you,so dont rate my answer if you dont feel to..
bye bye and good luck..keep me up to date with your situation
bye
Feb 06, 2008 | AOpen MX4SGVI-4DN2 (91.8B810.407)...
ASUS M2N-MX Motherboard Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
