Question about Pioneer S-DW1-K Subwoofer
My pioneer s-dw1-k sub keeps blowing fuses - Pioneer S-DW1-K Subwoofer
robotek
  • 1512 Answers
SOURCE: Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Posted on Feb 14, 2008
  • 54 Answers
SOURCE: Fuse keeps blowing?
The fuse is a protective device. Fuses dont blow unless the amp ( in your case ) is drawing too much current. DO NOT put a bigger fuse in. Obviously, there is a problem with the amplifier inside the sub. If the sub is under warranty, send it in for repair to an authorized warranty depot. If not it's not under warranty, then take it to the authorized warranty depot anyway. Why ? because they will have the schematics ( electrical diagrams ) to troubleshoot the unit quickly and it may be a common problem. If it is a common problem, the factory may have released a modification and possibly it could be covered under warranty under a factory 'goodwill' program. Good luck. Rob
Posted on Mar 03, 2008
SOURCE: sub woofer keeps blowing fuses
Try a 3 amp fuse
Posted on Jun 24, 2008
  • 56 Answers
SOURCE: klipsch sub 10 keeps blowing fuses
More than likely the power supply switching transistors have fried. Also check the large caps in the primary side of the power supply. If you don't know what your are doing do not attempt to fix the power supply.. very dangerous voltages involved !!! Send it to Klipsch for repair or purchase a Bash replacement panel http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750
Posted on Apr 13, 2009
ravichetty
  • 158 Answers
SOURCE: it keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Posted on Jul 22, 2009
I can't figure out if my crunch powerzone pzi 250.2. 1000 watt amp is compatible with my 2000 watt pioneer premier 12" sub, I seem to be blowing fuses will someone please help me out
There may be an impedance mismatch between the two. If the amplifier "sees" a load impedance of 2 ohms or less, for example, the fuse(s) will open to protect the output stage from failure.
Feb 09, 2017 | Pioneer Car Audio & Video
Why does the fuse blow?
try a different sub first, the fuse difference is not crucial but should try to use the one recomended by manufaturer
Aug 31, 2014 | Pioneer VSX-305 Receiver
Why does the fuse blow Instantly?
Link for the service manual: http://elektrotanya.com/pioneer_vsx-305_405.pdf/download.html On page 50 of the manual (36 of the pdf) it says for the "Sub woofer pre-out jack (Not available on the VSX-305 model) If you want to boost the low frequencies, connect to a subwoofer power amplifier" Your model will not drive a sub-woofer with out another amp. His sub may be a powered sub?
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
Amp pioneer 760 watts keeps blowing both 30 amp fuses when volume is raised
remember this amp when bridged can only go down to a 4 ohm load so if your subs are putting a load to the amp that is anything below 4 ohm than your going to have issues. is used as a 2 channel each channel can to 2 ohm but when bridged 4 ohm and above.
Aug 12, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
It keeps blowing fuses - two 12 inch cls subs 1
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
I have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
Jun 07, 2009 | Pioneer TS-W307D4 Car Subwoofer
Tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Mar 04, 2009 | Pioneer DEH-P6400 CD Player
Protection light keeps coming on
Check the wiring between the sub and the amplifier. That's seems to be the only thing left that could cause a problem. If it's shorted to ground or pinched so the conductors are shorted together, it could cause the symptoms you listed.
Oct 01, 2007 | Sony XM-2002GTR Car Audio Amplifier
Pioneer S-DW1-K Subwoofer Logo
95 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
