Question about Air Tools & Compressors
Kobalt 60 gal compressor 221565 book saYS NOTHING ABOUT WIRING PIGTAIL 240 VOLT I WIRED IT LIKE I THOUGHT IT WENT AND BLOWS BREAKER WHEN I PLUG IT IN HELP!!!!!!
    President:
  • 1,388 Answers
kobalt 60 gal compressor 221565 - 266549_300.jpg This is the most popular switch used on compressors but may not be exactly what you pressure switch looks like. You will need to determine how the contacts transfer power across the terminals. Lets number the terminals from left to right 1,2,3,4. On this switch notice how power crosses from 1 to 2 and from 3 to 4. You can determin how power is transfered on your switch by using meter. On this switch, leads from motor (load) would be connected to 1 and 4 and line in ()would be connected to 2 and 3. Determine with meter which leads from your pigtail are 115v each. Pigtails have either 3 or four wires depending on your wall plug configuration. You will only need the two 115v lines (connected to 2 and 3) and a ground wire connected to green screw. Under the cap of the pressure switch, there should be a wiring diagram to assist you for your particular switch. Good luck
Posted on Mar 19, 2011
What kind of oil for kobalt 221565 60 gallon
ordinary engine oil 10/30 or 16 oz synthetic oil ( lowes)
There are compressor oils on the market but as the most it has to do is lubricate the bearings and cylinders , engine oil is quite sufficient to do the job as it has all the additives needed to reduce wear , rust and inhibit moisture from the air compression
if it runs 12 hours a day 7 days a week then there will be a service schedule that you should be aware of but if it is just a home operation then every year or two would be adequate for a service
Jan 09, 2016 | Air Tools & Compressors
Screwed wingnut the wrong direction when trying to drain 60 gal. Kobalt compressor....can it be put back on?
call lowes there might b a service to get it fixed sound like u broke something to me get help
Apr 21, 2012 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
How do I wire my 60 gal 3 hp IR commpressor? What size wire, what size breakers, and where on the motor do I attach my wires. Motor says 15 amp, 220 volt. Thanks, Clint
I would use a # 10 wire size with a 30 amp breaker. The motor should already wired to the pressure switch unless it has a mag starter. If no mag starter incoming power should go to pressure switch not motor. If unit has a mag starter incoming power should go to top of mag starter.
Jan 12, 2011 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
We've purchased a Kobalt 60 Gallon, Volt 208-240, AMP 15.0 Air Compressor, Item #221565, Model #LLA3706056 without wiring diagram. Can you provide any assistance with this or refer me to a site that...
Your compressor is designed to be used in a shop situation (not portable) and is usually wired to a switch box similar to how your central air condenser is wired. It can however be wired with a short cord to a 220v plug. Your compressor motor is most likely wired to the pressure switch so all that you need do is to connect your pigtail from the pressure switch to the wall. You can buy all the parts that you will need at Lowes. You will notice that your motor has two wires going thru the contacts of the pressure switch. The inside cover of the switch will clue you in to wiring but if it does not have an illustration just match the black to black and white to white (110 v lines) and green to the ground screw at the pressure switch. Here is a good web site for another view: http://www.ehow.com/how_5041165_wire-air-compressor.html
Nov 04, 2010 | Ingersoll Air Tools & Compressors
Not heating
un hook the incoming power lines, turn the breaker back on, and carefully measure power between the 2 hot wires, not the ground. You must have 220 to 240 volts between these 2 wires, if you dont either the breaker is bad, or the wire is broken somewhere. If you have 240 volts to the heater, with the power OFF unhook the wires from both elements and use an ohm meter to test the resistance on the elements, both should be around 30 ohms and about the same, if not one is bad. Test across the elements after re connecting them and turning the power on you must have 240 volts across the elements when they are on, if you have only 120 or 0 then the trouble is the breaker or the wire.
Mar 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
HOW TO WIRE A KOBALT 60 GAL VERTICAL 208-240 TO BREAKER PANEL
i have a KOBALT 60 GAL VERTICAL 208-240 wired up like it should will not start or nothing
Feb 09, 2010 | Air Tools & Compressors
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 21, 2009 | Air Tools & Compressors
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Wireing three units together
yes, you did a good job. Sounds like you paralled them. Which is right buuuut what size are these heaters. Add the wattage of all of the heaters and divide by 120 and that is how much current you will be using. On a 20 amp breaker you can only pull 16 amps safely. I think you will be way over unless the heaters are 600 watts each. You are allowed 1800 watts on a 20 amp circuit.
Nov 06, 2008 | Fahrenheat Electric Convector Baseboard...
Air Tools & Compressors Logo
557 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
