Question about JVC Cameras
I have a JVC GY-DV5000 camera and two faults have developed. On occasion tapes get caught in the eject mechanism and end up sideways, these have to be forcibly removed. I also sporadically get a warning to clean the heads but am getting drop out even after a head cleaner has been through the camera.
SOURCE: JVC DIGITAL VIDEO CAMERA GR-D23EK
i have exactly the same problem. when i try to use the camera i get blank screen. i have try to reset but nothing.
Posted on Jan 16, 2008
guide2u
  • 461 Answers
SOURCE: Hi, i can view my
Seems like you might need to reset the camera. Try this,
Remove
1.0 Any connection from electrical point/PC.
2.0 Remove the battery
Leave your camera for at least 5 min.
Try to restart again....
Posted on Apr 11, 2008
welcomejee
  • 10594 Answers
SOURCE: My Digital Handycam bought in
How is picture result in your digital handycam?
It would be nice to provide exact model number to understand the problem in camera.
Posted on Sep 16, 2008
SOURCE: head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
Posted on Oct 10, 2008
quang123
  • 107 Answers
SOURCE: Hi, my JVC mini DV
It could be video head dust or the tape guide were out of alignment or it had been magnetized
In any case you should bring to JVC service center or JVC itself to repair this problem. They must connect your CAM into computer to check up and realignment DO NOT use the tape cleaning it won't help you sometime it cause more trouble such broken video head
Cheers
Posted on Dec 18, 2008
My jvc camcorder shows me a message that my unit is on safeguard mode
E04 is the only one that a consumer can try to rid. This error normally is the fault of a bad tape. I recommend removing battery and HOLD DOWN EJECT, while reconnecting battery so its the first command camera sees. if tapes eject, try a new tape.
Jul 22, 2014 | JVC Video Cameras
I have a JVC GR-D30U I get error E)$ eject and reinsert tape unit in safe mode. I can not eject the tape to reinsert it.
HI,
Please reset it.By removing the battery for 10min and then insert it back.Let me know the result.
Sep 01, 2008 | JVC Cameras
Video noise on jvc gy-dv500u
I have the same camera with the same problem.
Mar 09, 2012 | JVC -GY-DV500 w/lens, VF, Fuji 14x1:...
Sony dcr trv245e erroe code c32 20. I have had condensation issues with this camera in the past and now I cant eject the tape. can anyone help
The error code that your unit is now producing indicates that it is experiencing a tape transport problem - specifically that the takeup reel is leaving slack out of the cassette. This may have led to tape becoming caught in the mechanism and hence the cassette will not eject. This is one scenario although unfortunately it is not the only possibility.
The unit will probably need to go to a professional to have the cassette manually removed and the cause of the fault condition identified and rectified.
Jan 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Will not eject tape
If your camcorder is JVC GY-DV550 and having a tape jam problem, It could be mechanical problem such as pinch roller or tape may be loose inside. I will try this just in case of loose tape. At VCR mode, press FF serveral times then REW same. Now try eject. If that did not work, you should take it to professional service facility near you for further diagnostic. Good luck, -james
Mar 27, 2009 | JVC GY-DV550 Mini DV Digital Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Won't properly accept tapes/ tape won't fully insert
probably a bent cassette housing in the deck - time to seek out jvc authorized repair.
Jun 12, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Safeguard Mode 03
E03 is a mechanical fault on the mechanism,it may be the reel pulleys are bent and need to be straightened.If this is not a solution, take it to JVC agents,the mechanism is likely to be damaged if not repaired by the agents.
Aug 26, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Blue screen on playback footage
it seems to be a simple problem of dirty video head. check again after cleaning it.
Oct 26, 2006 | JVC GY-HD100 Mini DV Digital Camcorder
Cameras Logo
55 people viewed this question
Top JVC Cameras Experts
Parshiv Luthra
Michael Galve
Michael Galve
Are you a JVC Camera Expert? Answer questions, earn points and help others
