Question about Canon PIXMA iP4000 InkJet Photo Printer
I am getting 5 flashing yellow lights. As far asI can tell from the manual it appears I will need a new print head. Can it be cleaned or is it done?
  • 449 Answers
Yes, that is a printhead fail. Printheads are almost as expensive as a new printer for the Pixma iP4000. You can find the printhead on eBay, runs $50-$80. Better to put that money towards a newer printer. You can also look for scrapped or damaged i860, iP4000, MP780, MP760, MP750 model printers and salvage the printhead from those.
Posted on Mar 18, 2011
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
My Cannon i860 is blinking an amber light five times and then returns to green then blinks amber five times and so on. What is this error telling me?
I too went through all the cleaning processes on my i860 with its amber light blinking five times to one of green. After all that time and effort, I ordered a new head, replaced it, put the old ink carts back in, and presto, worked like a charm. Don't waste time and money doing anything else.
Jul 25, 2010 | Canon i860 InkJet Photo Printer
I960 resume light flashes yellow 5 times 1 green
Five yellow flashes indicate that the printer doesn't recognize the print head, or thinks that the wrong print head is installed. You can try to remedy this by opening the cover, removing the ink tanks, then removing the print head (lift the locking lever). Check that the copper contacts on the back of the print head are clean, then reinsert the print head, lock it in, and reinstall the ink tanks. If you still have the error indication, the print head may be bad and need replacing. Contact Canon for your options on this.
Feb 05, 2010 | Canon Office Equipment & Supplies
Canon iP 5200 orange light flashing 5 times
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair. I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Dec 22, 2009 | Canon Office Equipment & Supplies
Cannot print and printer won't reset
This error means "print head failed".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0055.
Nov 20, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
I have a Cannon i560 and I am getting 5 blinking yellow light the green and then it repeats. All indications is that I need a new print head. I want to be sure this is it before buying the print head.
5 blinking yellow or 7 blinking yellow in canon printers means you need to replace the ink cartridge or head with a new one. If you want to be sure, then take the print head and see if there is any burned area or damaged near the head and sometimes it is very small like a needle puncture. if there is, you need to buy a new one. if not, try to clean the head with 96% alcohol, let them dry before you try to put it back.
Sep 14, 2009 | Canon BubbleJet i560 InkJet Printer
The cartridsge printe red and blue fine. No yellow
The print head for the yellow color may be clogged. Check the manual to see how to turn on your print head's cleaning system. Run it until the yellow starts to print properly. If after running the cycle 4 or 5 times you still can't get any yellow to print you will probably have to take the printer to your local repair depot to have them diagnose the problem.
Jul 11, 2009 | Office Equipment & Supplies
Canon i865 printer
Hi! I've got same problem. Canon userguide says that 5 flashes means the print head is not installed/not properly installed, or it is defective.Not yet sorted problem out - new print-heads are expensive!
Feb 12, 2008 | Canon i860 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
627 people viewed this question
old marine
old marine
