Question about YouTube Videos
My youtube screen takes a very long time to load ,then it plays for 10s and it stops for about 10 minsand then plays for 10s and so on.....please help ! thank you!
  • 27 Answers
This can be caused by a slow internet connection.
* Tip * Pause the video and let the red line buffer. ( let it fill up a little bit) and then play the video.
Hope this helps
Posted on Mar 18, 2011
How do I stop youtube from buffering?
Buffering is the process of loading the video from Youtube servers to your screen. The buffering depends mainly on speed of your internet connection. You can try the following options
  1. Switch to a highspeed internet connection
  2. Once the video starts, press the pause button. Leave it for 5-10 min and then try playing
Dec 15, 2014 | Cell Phones
Why does YouTube keep on stopping when playing?
Any delay or lack of bandwidth between your computer and the YouTube server as well as a high server load can cause a video to pause. Your ability to play videos is also limited by your connection speed.
You can reduce your playback quality in order to get fewer stops and starts but, you will get poorer video.
Jan 01, 2013 | youtube.com
My video on youtube keeps stopping and starting. It is fine on live movie maker. What's wrong? Does it take too much memory?
The video buffers. That's it may seem to stop, bec it needs to load first. Try waiting for your video to load first before playing it.
Mar 25, 2011 | YouTube Videos
Playing music or anything with dialog music will start then stop and say loading then start then stop and say loading this is continous
This happens to me. i usually let the video load all the way the first time then replay. Usually it plays through without breaks.
Jan 03, 2011 | YouTube Videos
How can I get youtube to just play thru without stopping to load every 4 or 5 seconds?
You know streaming video is so slow.
So, try to download the YouTube video with a professional Youtube downloader--It's totally free.
Jan 02, 2011 | YouTube Videos
When i play a youtube vidio it keeps stoping while in play
I think i know what your problem is....
When you load any video on Youtube it is visible in the form of a red bar as it loads......it hasnt completely loaded until the red bar reaches the far side of the screen....then there shouldnt be any issue playing it back......your issue is the playing has caught up with the loading and obviously it can
JonnieC
May 17, 2010 | YouTube Videos
Why does youtube stop playing and then starts again while a circular motion appears in the middle of the screen?
It is very simple youtube uses a streaming system based in flash, this means that the youtube player calls a file of an indetermined size stored in a server, did you ever noticed that in the playing bar below the video there is a red bar that fills the bar progresively this is the bar that shows the amount of video downoading of the file in the server, when the size of the file is to high it takes more time for the video player to download it, what happens is that the playing time is shorter than the download time so the player reaches the amount of video played faster than the video downloaded and it stops until the download progress a littlle bit more to continue playing the video, so if the video has a smaller file size the less the player stops, but small size videos could mean a down of quality in the image of the video depending also in the length of the video and in your internet connection speed.
Good luck
May 06, 2010 | YouTube Videos
Have a mc culloch chain saw pro mac 10-105. No spark-need new coil? Do they still make and where might I find one?
I do find a 10-105 could it be a 10-10S model 600111 follows:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/8f167f396637c29d88256c2e0073560e?OpenDocument
Change the plug and try it, very cheap insurance.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Rotating the flywheel in a darkened room with the plug removed and the ignition on may reveal a leaky plug wire. Often a little heat shrink tubing will stop any leaks.
Model "11-600111-06 (02 through 06 suffixes possible) follows:
http://www.ordertree.com/modelinfo/MCC/11-600111-06-PRO-MAC-10-10S-08%2F82-to-Current-IPL-216062-01/139.11-600111-06-PRO-MAC-10-10S-08%2F82-to-Current-IPL-216062-01.1.59.1.html
See the "Powerhead Assembly" item 11; part number 223708-01.
If you determine the coil is bad I found one here:
M & D Mower
http://www.m-and-d.com/parts.html
Coil
http://arinet.lookupparts.com/AddToBasket.aspx?Qualifier=MCH&Name=223708-01&Quantity=0&SellerId=1017594&Username=Default
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 12, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
When i go on you tube or try to down load any video and play it the video skips and stops (video stops) starts again but never plays all the way through without some tpye of interuption. when the video...
hai from your mail i have understood that you are having some troubles on playing clip that is downloaded from youtube.i thing flash player 10 that you use will not be installed properly.kindly check your instalesion progress and reinstall it.hope the provided information is help full.thank you for contacting FxYa.com
Mar 21, 2009 | YouTube Videos
Wireless
Reset your modem. Turn it off, wait 10 seconds, and turn it back on.
Sep 02, 2008 | Internet Computers & Internet
YouTube Videos Logo
206 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
