Question about Epiphone SST Studio Guitar Acoustic
Hello i have a epiphone sst studio ,but the jack is un connected,que you send me info about how connect,tanks for the info
  • 94 Answers
YOU CANNOT CONNECT IT BACK , YOU CAN CONNECT IT BACK ONLY IF YOU TAKE THE WHOLE GUITAR APART.
Posted on Mar 23, 2011
I need a wiring diagram for epiphone sst
You should be able to find what you are looking for here http://www.gibson.com/Service/Tech/Schematics/
Feb 15, 2012 | Epiphone SST Studio Guitar Acoustic
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
Looking for year model for an epiphone sst studio serial # 10082302339
check out giovanni stores do will be able to help you, it belongs to the chet atkins family guitars
Dec 01, 2011 | Epiphone SST Studio Guitar Acoustic
Epiphone BB King Lucille guitar treble pickup in mono mode
Realize that when you plug into the one jack it disconnects the fingerboard pickup from the mix.
DO NOT USE "stereo" cables as it is intended to use TWO MONO cables, one for each side of the stereo.
IF you plug into the one jack that will connect to the bridge pickup, it will disconnect the fingerboard pickup from the mix BUT leave the fingerboard on its own jack.
That same jack will have BOTH fingerboard and bridge pickups IF the second jack (bridge) is not plugged into.
This is according to the schematic. If you find that yours works backwards, then either the schematic is wrong OR your guitar pickups may be electrically swapped.
Apr 19, 2010 | Epiphone B. B. King Lucille Electric...
I tripped over my amp chord while it was in, and now my amp wont make any sound at all. any suggestions?
First, try a different cable. Often in this kind of accident, the connection is broken between the wires in the cable and the plug on the end of the cable. (The cable can often be repaired by soldering the wires back onto the plug.)
If that doesn't help, it's possible the input jack on your amp was damaged. It is a relatively simple job for an amp technician to repair or replace an input jack if this is the problem. Expect about 1 hour of labor and about $10 in parts.
Sep 13, 2009 | Epiphone Les Paul Studio Electric Guitar
Need to replace output jack and plate
If this is a classic guitar you should take the fretboard problem to a luthier as you could de-value the unit by working on it yourself.
The jack you can replace yourself. Just connect the wires to the new one the way they came off the old one. There are ONLY two wires. You can get replacement jack from severaal sources.
Aug 24, 2009 | Epiphone Les Paul Studio Electric Guitar
Epiphone Sheaton II guitar setup
This will help for starters:http://www.epiphone.com/images/EpiOwnrsManul.pdf This site has good info in the discussion:http://www.thefret.net/showthread.php?t=4728 There's info here too:http://epi.p3net.net/bbs/index.php.
Aug 09, 2009 | Epiphone Elitist Sheraton Electric Guitar
Jack on guitar looks like a wire broke off. One blue wire still connected. No loose wires floating around! Should there be 2 wires connected to the jack itself? Which two?
There should be two wires connected. One goes to the jack tip while the other goes to ground. One lug on the jack is connected to the part touching the sleeve on your cable while the other will contact you cable's tip. There is another wire in there somewhere.
Jul 01, 2009 | Epiphone Les Paul Studio Electric Guitar
Output jack on a Epiphone Les Paul came out and I ned a schematic
google your problem. i have found scematics on everything. i'm currenly changing out the pickups on my les paul, and saw the diagram on your soldering setup. i've done these myself. i was a little worried at first, but it turned out to be pretty easy. good luck, scott
Apr 07, 2009 | Epiphone Les Paul Studio Electric Guitar
Epiphone SST Studio Guitar Acoustic Logo
245 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
dave nyman
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
