Cannot read the sd cards SDHC cannot access external reader says I have no rights to read MMC-SD
  • 29 Answers
Is your SD-CARD password protected (usually set up by phone)?
Posted on Mar 18, 2011
My lg does not read 2gb sd card.it tell me to insert a new one.Bt it can read 128 mb sd card
Your 2 Gb is not just an SD card, it is a SDHC card. The first 2Gb SD cards, still were SD, but 2Gb was the limit for the FAT 16 and 32 format and for the normal SD cards. The same happened with the hard disks. They developed the SDHC card, and made the new hardware downward compatible with the old SD cards. So in a new camera, you can insert SDXC, SDHC, SD and even MMC cards. But the cameras, card readers and phones, who were made for SD, can't use the SDHC or SDXC cards.
SDHC can work with memories up to 32 Gb and from that on, it is SDXC.
There still should be some 2Gb SD cards around, but not sure you still can fine one. The producers of memory cards now only make SDHC cards and up. Perhaps you only can get some 1Gb cards as SD card, but perhaps nobody will ever make these cards anymore.
I mannaged to buy a 4 GB SD card a few years ago, but that was the last I ever saw in the capacity. 25264488-uil2tdgcy05knvgzh4oup5lj-2-0.png
Nov 01, 2014 | Cameras
HOW TO FORMAT CARD FOR KODAK C703 CAMERA
In settings you find (on the bottom) Format.
You could try formatting in a computer, using an external card reader and choose the FAT16 or FAT 32 format.
But be aware if you bought a new memory card it should be a SD card. Not a SDHC or worse SDXC.
The camera can only handle MMC and SD cards. Today you can't find much SD cards. Because they already started to make the 2Gb cards in SDHC. (High Capacity) these cards look the same, but can't be accessed if your system (Camera) can't handle the large file systems.
So if you need a new card, look for the smaller like 1 or 2 Gb, but with only SD printed on them. As soon as you see SDHC or SDXC you can't use them in this camera. The newer ones can.
Jul 15, 2014 | Kodak Cameras
Targus High speed SD/SDHC/MMC Micro SD-TF Card reader could read any of the SD/SDHC/MMC cards earlier when I had purchased it on my Lenovo Think Pad laptop having Window-7 . Now it is showing, when in
This is more likely a problem with the card. If the partition tables corrupt then Windows will see the card but won't be able to read data on the card. You will need to format the card.
Jan 30, 2013 | Electronics - Others
My gateway computer won't read my 32gb sdhc card
If your current card reader isn't compatible with SDHC cards then you need to get one that is. While SDHC cards fit into the SD slot, they care electronically incompatible and won't work in devices not designed for them.
Dec 29, 2012 | Cameras
I bought a 2g sdhc memory card for my sea and sea dx-860g today and I get a card error when I try to use it. Is this because it is an sdhc rather than an sd?
hello jwill..... your camera External memory: Supports SD/MMC cards
I believe you are correct in saying that it does not support sdhc. Joe
THanks for choosing Fixya!
Feb 16, 2011 | Sea and Sea DX-860G Digital Camera
How do I format a 4MB SDHC card for this camera
"SD and MMC flash memory cards marketed by Kodak, Kingston, Sandisk, PNY and other flash-memory card manufacturers will work with the EasyShare C643. The digital camera supports standard MMC cards and SD (secure digital) cards, but not SD High-Capacity (SDHC) or SD Extended Capacity (SDXC) cards."
Read more: Compatible SD and MMC Cards for a Kodak EasyShare C643 ' eHow.com http://www.ehow.com/facts_7590028_compatible-cards-kodak-easyshare-c643.html#ixzz1BijGdWKF
Jan 21, 2011 | Kodak EasyShare C643 Digital Camera
I put a sd memory card from my camera in my computer. the computer hasnt uploaded the pictures or done anything.
I guess you have a built in card reader? Is there any chance your camera SD card is SDHC? Some card readers including built in types and those that you connect to a USB port have trouble with the later and faster generation SDHC cards but are happy with plain old SD cards.
If you are using an external card reader, does it work in another computer? If it does work, then the problem is with your computer.
If you have a built in reader, can you borrow someones external card reader that you know and does work with SD and SDHC cards?
Can you try an older SD card in your current setup? If that works OK then it's the issue with SDHC that is your problem.
Easily fixed by buying yourself a $10-20 external card reader
Cheers,
Steve
Aug 11, 2010 | Computers & Internet
UNABLE TO ACCESSMY 4GB MICRO SD CARD
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
I cant seem to access MY SD Memory Card from my New Camera through the SD Card slot on the Front panel of My Aspire M1201 - The Green LED is on but no pop up and i cant find the correct the section to...
Newer cameras may have SDHC cards - these have a high capacity. Older computers can't read the newer SDHC cards - they can only read the old SD Cards. The SD card and SDHC cards look exactly the same. The SDHC card will probably say "SDHC" on it somewhere. Fortunately you can buy a USB SDHC card reader for a computer for around £2 on amazon. I would buy one of those. You could search the internet for "usb sdhc card reader".
Jun 13, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
