My Sony CRF-5100 radio only has static when I turn it on. I think a good cleaning is needed with contact cleaner. I am not sure of the best way to take it apart so that I can get at the tuner dial to clean it. I have a copy of the original service manual that gives detailed instructions on how to completely take it apart but don't need to go that far. Instructions on how to disassemble it to just where I need to go would be appreciated,
  • 6 Answers
SOURCE: NEED TOSHIBA 2400 SERVICE MANUAL OR DISASSEMBLY INSTRUCTIONS
Hello you can tye following url. http://repair4laptop.org/disassembly_toshiba.html Try it.
Posted on Jun 29, 2007
CompuGuy44
  • 432 Answers
SOURCE: Instruction manual for 8910 proheat cleaner
Heres the website to download the manual. http://www.bissell.com/images/UserGuides/1699_306.pdf
Posted on Jul 20, 2007
frit
  • 67 Answers
SOURCE: mp3 player no instructions
go to www.iriveramerica.com. click on support, then ultra portable support, then T10. download user manual. You should also be able to download a music manager for loading music onto your player from the website. Windows media player works well. you can also use Rhapsody.
Posted on Jul 29, 2007
  • 7 Answers
SOURCE: FM Tuner?
Press far right button (play/stop) and hold it down for about 3-4 seconds. Now press A--B button (3rd button from right) and audio play shows on the screen. Press this button one more time and FM radio shows on the screen. Then press far right button and FM can now be tuned in. You can also download the instructions from www.sandisk.com
Posted on May 06, 2008
rizla
  • 1463 Answers
SOURCE: how to disassemble printer
hi milo
just seen this post have you tried the help / support from canon here Canon PIXMA MP210
riz.
Posted on Jun 06, 2008
Volume switch on Panasonic radio has scratchy static sounds
Sounds like oxidized contacts.
If volume is a turn-knob, then wiper-track (inside potentiometer) is worn.
If it's a PTM (push-to-make) standard button, the button contacts may be dusty/dirty/oxidized.
Suggest you:
buy a contact cleaner such as Servisol,
open case,
identify controls
and squirt liberally to wash out any gunk.
Move/press/wiggle scratchy one to help 'scrub' the contacts clean.
If this doesn't help try have control replaced.
Oct 11, 2017 | Panasonic Radio Communications
My honda crf 450x 2006 model wont start?
you gotta go threw a kinda "check list" when this happens.To start off is filter clogged then remember your choke, maybe drain the carb bowl spray some cleaner in it ,or better yet clean it completely and while its out check your reeds make sure they are fine,take spark plug out check for correct gappage maybe clean that up with fine grit sandpaper.That should be good ..best of luck
Mar 11, 2013 | Motorcycles
Radio won't turn on all the time. It works fine when it does. I cleaned the on off and it still does this. HELP
Try spraying electrical contact cleaner down the shaft of the on / off / volume control (after removing the knob itself) with the radio unplugged. Operate the knob if possible to "work" the cleaner into the mechanism - or gain access to the control from the back (inside) of the radio. These types of controls have an open snap action switch that is often piggbacked on the mechanism that may be visible or behind a tin protective cover. You may need to dismantle the cover to effectively flood the switch with cleaner. Read the label of the contact cleaner before using - as some may attack plastics, etc.
Feb 10, 2013 | Audio Players & Recorders
HELLO, I HAVE A AUDIOVOX #CD198. THE RADIO WORKS BUT WHEN I MOVED THE FUNCTION BUTTON ALL THE WAY TO THE RIGHT TO LISTEN TO CDS ALL I HEAR IS THE CD TURN BUT NO MUSIC AND THE SAME THING HAPPENS WHEN I...
hi,if the function selector of your audiovox is an manual selector switch you need to clean the contacts of it by spraying it with a contact cleaner (windex) spray the cleaner directly to the contact of switch then rotate the switch repeatedly until contact is clean be sure to unplug the unit before applying the cleaner.you need to open the cover of your machine to be able to access the function switch..good luck!
Jun 30, 2011 | Audio Players & Recorders
I have a NAD turntable. I have noticed that on occasions there seems to be a background crackle.. Thought it was dust at first !! Have swapped the connection over where the turntable plugs into the amp....
Either you have a poor earth connection or you are getting a lot of static from the records you play. The best way of getting rid of static is a spray you can get for cleaning records. Search on-line for Anti-Static Record Cleaner.
Jun 15, 2011 | NAD 533 Turntable
The push buttons give off static when pushed and have to be held in place to hold a station! Is there a remedy for this? The problem actually started soon after I got it.
A can of contact cleaner will usually fix the static problem unplug the unit, and use the spray tube nozzle from the back side to reach the push buttons, you will have to push them in and out to clean the contacts on each slide switch. while you are at it clean the volumne and tone pot, the same way. a good brand of contact cleaner will not affect anything in the radio but will remove any dirt from the contacts. This is the usual cause of a loud static noise in most radios. A poor contact.
As far as the push buttons not staying in, I notice the red wires from the transformer are lead around the front of the radio, perhaps one has lifted enough to block the buttons from latching. Or the latch on the buttons is worn or broken away.
Dec 27, 2010 | Grundig Classic 960 Shelf System
Excessive static
Constant static is a sign of either a bad/low battery or a defective radio. Sorry. You might try switching the batteries from a known good radio to this one to see if the problem is solved. Clean your battery contacts with a pencil eraser to assure good connection. If changing the battery does not solve the problem, the radio is defective and will need retired.
Best regards.
Apr 07, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Get a lot of static when try and turn volume down low.....in fact, sometimes it is hard to get sound when you turn the volume down....it is either full blast or silent.....lots of static like noise when...
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
Dec 03, 2009 | Tivoli Kloss Model One AM/FM Radio
Sony cd radio cassetteplayer says no disc when disc is in player
Make sure your cd medium is compatible with your Sony unit. Some cd types that have been burned on a computer may not be compatible. Check your instruction book for your Sony unit to see what types of cd medium you can use.. Also, the lens on you cd player could be dirty and may need a cleaning CLICK HERE to see the Radio Shack lens cleaner. You can also get them at may other locations like Walmart, Target, Sears, and Best Buy. Good Luck! : )
Nov 10, 2009 | Sony CFD-F10 Radio/Cassette/CD Boombox
Sony Dream Machine clock radio
0) Read the last answer first :) it is the most likely.
1) Make sure that the noise is electronic, not mechanical,
a) Electronic noise comes from the speaker
b) Mechanical nose originates in the clock
(older mechanical clocks only)
c) Clocks come in 3 varieties:
Electronic
Mechanical "Flip Leaf"
Mechanical "Motor/ Gear" driven.
2) Assuming that your clock is electronic, there are
only two possibilities for causing static.
a) Extremely intense electromagnetic interference,
as in radio waves, from a thunderstorm or a powerful
transmitter nearby, such as a HAM radio or even
an active cell phone.
Intense electro-magnetic waves can be picked up by
internal wires within the radio which act as an antenna,
rectified (demodulated) by internal diodes and transistors,
filtered by internal capacitors and the speaker's inertia,
and still present enough audio frequency energy to the
sensitive speaker coil to be "quite" audible and irritating.
This can happen even with the power off, when the
interference is so strong that it needs no amplification !
This happens to my computer speakers, every time my
cell phone rings, and starts transmitting a return signal.
3) The power switch is intermittently shorting causing a small
amount of DC power to enter the radio, the more intermittent
the switch, the more noisy it gets.
This causes my old clock radio to turn on by itself when its
not supposed to.
The cause of the problem in either in the main power/ mode
switch, or in the clock driven switch or relay.
4) Old switches and volume controls get oxidized with time
and/or bridged by products of corrosion. The simple solution
is to clean them using a good aerosol contact cleaner,
available from an electronic shop for about 10 bucks.
Simply spray the cleaner into all the switches and controls,
while vigorously exercising each switch or control back and forth.
Make sure that you use a safe "electronic cleaner" designed
for the job. It must be safe on plastics, non-conductive, good
solvent and it must evaporate quickly. Don't breath the stuff !!!
Typically the spray will contain TF (tri-fluoro-ethane), or some
other freon substitute.
Freon (Di-fluoro-di-chloro methane) is bad for the ionosphere,
now illegal in most countries for that reason.
Also stay away from Carbon-Tetra-Chloride, which is
VERY toxic.
Do NOT improvise, or use acetone or alcohols, which may (will)
melt the plastic, causing the controls to permanently seize.
Get electronic contact cleaner from an electronics hobby shop.
Good luck. Martin
Please rate my answers.
Jul 04, 2008 | Audio Players & Recorders
89 people viewed this question
 Grubhead
Grubhead
