Question about Daewoo Microwave Ovens
I have a Daewoo combo microwave/convection oven model wm1010cc. The door handle is loose, it looks like the screws are unscrewing. How can I tighten them?
  • Pwtworangasm Mar 19, 2011
    I had already done all that was suggested by the previous "expert". After removing the inner panel I still have no access to the screws as there is a metal frame work covering them as well. Can you tell me how to remove that so I can get at the screws without damaging the door or wrecking the retaining clips or whatever is holding the frame work in place?
    The second solution was very helpful. Thanks
  • 4,924 Answers
Usually the screws are hidden under the cover of the handle ..and this will have to came out in order to screw them in place again ...The cover I'm talking about i s..the front cover ...facing you ...the part that gets in the palm of your hand...Take a good look cause this cover is usually just clicked (stapled ) in ...and if you insert a sharp object ..and you take it step by step from a side...you can get it out..
Or the ends of the handle comes out and after that the face of the handle ..slides out...and reveals the screws...
Posted on Mar 19, 2011
    Guru:
  • 262 Answers
Here is a video on how to do this.
Click on the link http://www.youtube.com/watch?v=PQe9DE3FS20
  • Daewoo Master
  • 6,993 Answers
you will be needing a Philip screw drive that you will be using to tighten the screw.
Depending on where the screw is located, it might be an easy or difficult task.
Check the front of the door handle and observe if you will see any screw. If you don't see any, further check for any rubber on the door handle because sometimes screws are hidden on the door handle.
If you don't see any handle, then it means the screw is holding the handle from the inside.
So open the oven door, check the door handle's area from the inside, and you should find the screw. If you don't find the screw, then something is covering it. Carefully remove whatever that is covering the screw from the inside of the oven door and after tightening the screw, make sure you cover whatever you have removed properly.
I hope you understand the above.
Good luck.
WM1010CC Microwave Oven won't stop cooling
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for free help.
Nov 27, 2016 | Daewoo WM1010CC Microwave Oven
Help fixing a kitchenaid microwave oven/hood combo door handle
The door handles on most appliances, like outside cars & truck handles, are secured with screws from inside the door.
You will need to take the door completely apart to tighten the screws. This may be a very hard job, as it needs to be reassembled as well. God bless your efforts.
Oct 24, 2016 | KitchenAid Microwave Ovens
Daewoo rotating base
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
May 24, 2009 | Daewoo KOR-630A Microwave Oven
Caught Fire
i need the model number
Oct 14, 2008 | GE JVM1870 Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
May 02, 2008 | GE JVM1870 Microwave Oven
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
75 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
