Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence problem i was seeing a red line across the screen and double,could adjust convergence alittle changed the amps with stk110s,didnt soder yet gave a test red went away but still seeing double and convergence adjustment wont move at all from the remote control.should i soder stk110s before testing does it matter,could it be the resistors?
I can't imagine how you would have enough electrical contact on the STK110s without soldering them in place, so I would think you need to solder them before testing further. Running the TV without them soldered in place and properly heat-sinked could cause additional damage to the TV and/or other components.
Posted on Aug 04, 2008
Words ars doubled and arching, green and purple across parts of the screen, picture blurred
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 26, 2010 | Toshiba 53HX71 53" Rear Projection...
Multipoint blue convergence cannot be adjusted
Sound like you need to replace the STK's and any blown pico's on convergence board.
Jan 20, 2008 | Philips 60PP9202 60" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Seeing doubles
there is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
May 22, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Model 43FDX01B double vision with red ark across bottom . and no user manual.
*Screen Looks 3-D
*Colors wont align
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Changed stk110s but still seeing double
You will have to unsolder the resistor and lift one side out of circuit. The convergence resistors are usually located right next to the Ics and there should be nummerous that are all identical with the same color bands or markings.
Aug 03, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence problem with 53tw53tg
did you check the convergence feed resistors? its not uncommon for a few of those to go open when the ICs go out.
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
