Question about Metra 99 5715ld Ford TaurusMercury Sable 1996 Up Dash Kit
I'am not getting power to the fuel pump - Metra 99 5715ld Ford TaurusMercury Sable 1996 Up Dash Kit
  • 3,799 Answers
Check Fuel pump fuse first. If that doesn't help you may find that your cutout switch has tripped. This can be caused by a hard bump in the road or it may have been switched off inadvertently. (It is designed to cut the fuel pump in the event of an accident.
Posted on Mar 18, 2011
Changed fuel pump not pumping fuel not working correctly relay good getting power second fuse for fuel pump not working one wire fuel pump in back getting weal power 97 Saturn sl2
If I understand your post correctly you have a fuse for the fuel pump that is blown or blowing. Until you resolve that issue the fuel pump probably will not get enough power to run. If it blows when you replace it the you have a wiring problem to your fuel pump. Most replacement gm fuel pumps come with a replacement plug for the fuel pump. Make sure you use it if yours did as there have been lots of problems with the wiring plug being damaged due to the high current draw of the fuel pump.
Jul 13, 2016 | Saturn Cars & Trucks
05 Chevy cobalt have no power to fuse block for fuel pump
You have no voltage at 15 amp fuel pump fuse in the under hood fuse/relay center ? There is a fuel pump relay also in same under hood fuse box. The fuel pump fuse gets power from the fuel pump relay. The ( PCM ) engine computer controls that relay, gives power or ground electronically to turn the relay on giving power to the fuel pump through the fuel pump fuse. You could have a bad relay or an anti-theft system problem . What engine does you vehicle have 2.0 L or 2.2 L the 2.0 L engine gets power differently to fuel pump .
Dec 28, 2014 | 2005 Chevrolet Cobalt
No power in my fuel pump fuel relay for fuel pump
Get yourself a wiring diagram & study it & then
start testing the fuel circuit
How would you know whether you had power or
now power, to anything, working blindly?
You listen to what your told.
I wouldn't-- you may have changed a good fuel pump
I NEVER walk to any vehicle without a wiring diagram
How would you learn the system & the circuits, without one?
Oct 16, 2014 | Cars & Trucks
New fuel pump still wont start
check the pressure sensor in the fuel manifold as it directs power to the CPU to turn on the fuel pump
Apr 06, 2014 | 2001 BMW 325i
Fuel pump
the fuel pump is supplied power via the fuel pump relay. The relay gets power for the fuel pump through the ECM B fuse. This fuse also supplies power to the vehicle control module.
Apr 05, 2013 | 1999 GMC Jimmy
No power to fuel pump or pump fuse on a 1996 saturn sl1. whats up?
The fuel pump fuse gets its power from the fuel pump relay, which is located in the Instrument Panel Junction Block.
The fuel pump relay gets its ground from G102, which is located just forward of the left strut tower.
The fuel pump relay gets its power from the Powertrain Control Module Connector "C" Pin 10 ( DARK GREEN/ WHITE wire) for the primary side of the relay.
The sencondary side (the side that provides power to the fuel pump fuse) of the fuel pump relay gets its power from the IP BATT Fuse (30 Amp) HOT AT ALL TIMES in the underhood fuse block.
This should be enough information to figure out why your fuel pump is not getting power. Let me know what you find.
Apr 14, 2012 | Saturn SL1 Cars & Trucks
Not getting fuel to the carburator. I have poured fuel on the carburator and it started, then it shut down. The fuel pump was replaced about 2 years ago..
check fuel pump relay on firewall passenger side if it has power and power when the key is turned on will click test power through relay to fuel pump disconnect connector at fuel tank make sure you have a good ground test for power at sending unit when key is os or in start if power the sending unit has rotten corroded wire going to fuel pump you will have to remove the fuel tank test power right at the pump if there is no power replace sending unit if power a pump use teslight one end on ground terminal and other lead on power terminal at pump if you have power replace the pump
if this is helpful plz leave a comment like and if you need more help ask once you eliminate pump good luck
Jan 16, 2011 | 1997 GMC Sierra
I have an 89 ford bronco. The inline fuel pump is not getting power. Where does the pump get its power from? Where is the fuel pump relay, and where does it get its power from.
The pump gets it's power from the fuel pump relay under the hood driver side fender well there should be three relais under the plastic cover there is a windshield wiper motor relay a fuel pump relay and i forget the third but swap relays around and see watch you get
Nov 27, 2010 | 1989 Ford Bronco
Metra 99 5715ld Ford TaurusMercury Sable 1996 Up Dash Kit Logo
67 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
