Question about Refrigerators
Freezer section is not freezing. - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
Everything is freezing in the vegetable drawer
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
This should help.Thanks.Helpmech.
Oct 31, 2011 | Kenmore Refrigerators
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Haier refrigerator freezes in freezer but does not get cool at all in the cooler section
my refridgerator freezes too much in the freezer and does not get cool in the cooling section
May 30, 2010 | Haier HTE18WAA Top Freezer Refrigerator
The fridge section does not cool items. The Freezer is freezing
Hello,here are a couple of tips that i think can help
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer.
Thanks
May 28, 2010 | Magic Chef CTB1821AR Top Freezer...
Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
Sep 21, 2009 | Kenmore Refrigerators
Freezer is defrosting
Many times, on a fridge with automatic defrosting, there is a sensor at the back of the freezer section (behind the plastic) that detects a freeze condition - sometimes these go bad, In normal operation, usually once a day, the timer sends a signal through this sensor and if it shows a frozen condition, it activate a heater (yes, a heater) in the freezer section that melts and defrost the coils. If this system stops working, the ice builds up and closes up the air passages to the fridge section, causing it to warm up, while the freezer section ices up!
Check for icing and maybe try defrosting a little by removing power for a little while. Move any food to another fridge while you are fixing it. The freeze sensors are easy to change, but be careful - electricity can kill. Always hire a professional if you have any doubts about your ability to perform the work yourself.
Aug 30, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
