Need a New Bulb Soon per the message on the TV screen when you turn it on . Where is it and what is the part number? Made August 2006.
  • 604 Answers
You don't list make and model of your set so its difficult to be precise, however most of the lamps are assessable either from the side (most often) and sometimes in the back. Look for a door about 5 inches square, it should open and inside you will find a little handle usually a loop that you can grab with your finger, pull on it and the lamp housing will come out. You can find the part number on the housing or on the lamp itself. Better yet is to type a Google search like this, needed,projector lamp for (your make and model) flat panel television, you should find several sources for the lamps. you will pay approximately 60 dollars for the lamp itself and maybe 30 to 40 more for a lamp already mounted in a housing that will fit your set. the lamps are not hard to install into the houseing if your handy and "careful" not to touch the bulb with your bare fingers. (the grease on your fingers will cause the lamp to burn out prematurely. good luck
Posted on Mar 18, 2011
Lamp light blinking red
From your description it sounds like the lamp bulbs needs to be replaced.
You need one of these:
http://www.amazon.com/Hitachi-50VS69-Watt-RPTV-Replacement/dp/B006C58MOI
NOTE: DO NOT TOUCH THE GLASS PART OF THIS BULB. The smudges from your fingers can show up on the image projected onto your screen and make things look blurry.
Once you have the new bulb then turn off the TV and unplug it. On the back panel there is a rectangle on the left with a screw holding it on. Use a philips head screwdriver to loosen the screw then slide the rectangular panel to the left and pull it off. Inside will be the old lamp bulb. Use the screw driver again to remove the screw holding the lamp bulb in and pull the lamp bulb out (it may be hot). Insert the new bulb and then screw it back in. Place the panel back on and screw it back in as well. Make sure the screws are tight or the TV may not turn on. You can now plug the TV back in and turn it on. If done correctly this should resolve the issue.
May 07, 2013 | Hitachi 50VS69 50" Projection HDTV
I have a Mitsubishi dlp WD62625 tv and I had a new bulb installed in Nov. 2010 by a tv repairman. After installation he re-set the tv but the yellow/red light wouldn't go off. So everytime I turn the tv on...
the bulb wire go to the ballast board, they do wear out over time but is usually down to capacitors, also depending on how much you watch the tv its about time to change the bulb as they only last a certain amount of time any way. when the tv is reset properly it will count down on time used. from new bulb. its only an estimate, if you are having difficulties seeing the screen the bulb is on its way out.
Jun 12, 2017 | Mitsubishi WD-62725 62" Rear Projection...
New bulb in a hp vp6220 projector
We have a number of these at the school I provide support at and just recently I've had to replace the lamps in six of these.
I've found the method HP details a bit hit and miss, i.e. you might have to try doing a few times before you get the message. First power off the projector and then remove all inputs to it, it won't work if you have anything still plugged in other than the power. Re-apply the power and then press and hold the up button. You should now get a message on the screen 'reset lamp hours for new lamp - press [auto sync] to reset', press the auto sync button as soon as you see this message as it soon goes off.
You can then check via the menu to make sure the lamp hours has been reset to zero.
Mar 12, 2009 | HP VP6220 Multimedia Projector
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Red light front of tv
If you still have a good picture, then NO, just reset your lamp timer. The instructions should be in your owners manual.
Feb 01, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Samsung hdtv HLP5085wx no image. Smelled something burning and sparking, turned off the tv. Tried turning it back on = have sound, NO image!
OMG! Dude, your screen is just plain fried. You don't need a new screen though, You just need a new bulb for it. See, behind the screen is a light bulb (unless your T.V. is plasma screen), sometimes two or three, and that burning smell was the bulb blowing (like when you need to replace a light bulb in a lamp or something). I don't know where you can find a new bulb, but once you replace it everything should be fine.
Oct 05, 2008 | Televison & Video
PT Cruiser Brake Light
The bulb in the rear light has burned out and to replace it follow these instructions: 1) go to your owner's manual to find out the part number. You can find and purchase the replacement bulb at Target, any auto parts store and even at Walmart for under $4.00; 2) pop open the trunk door; 3) get a phillips screw driver and unscrew the 2 screws holding the rear brake light fixture to your car body; 4) as soon as you turn over the fixture you'll see where to pull out the burned out bulb and replace it with the new one(s). Good luck!
Jul 14, 2008 | 2006 Chrysler PT Cruiser
Hitachi ultravision
It could be you need a new lamp again (your might have gotten a defective one) or "temp" is the temperature sensor that is located on top of you lamp, could be bad also. If the lamp gets too hot, the temperature sensor will shut down you lamp so your TV will not catch on fire. If your temperature sensor has gone bad, your lamp will not turn on at all.
Mar 22, 2008 | Televison & Video
Air Filter message
Soulvisitor has it right. I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it. Thank you Soulvistor you saved us at least $100.00
Nov 14, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
