Question about Canon Pixma iP6000D InkJet Photo Printer
Paper will not feed in Canon Pixma iP6000D printer
Paper does not feed. If it does, it shuttles back and forth as if it is trying to locate it. It does not feed through. And, when it does print, the print is off location relative to the paper. Please HELP!
    Champion:
  • 214 Answers
Hi, clean the feed roller or get it cleaned from an authorized service center. use good quality paper
thanks
Posted on Aug 15, 2008
My Canon Pixma ip6000d isn't printing any images or text. There is plenty of black ink, I ran the tests for alignment and nozzle check. The paper feeds through fine and it sounds and acts as tho
Did you try a test print. Most printers have a option to set the ink color, this is done when your computer asks you if you want to print. Look for an options tab and search for ink color options pick black only and try a test print. The test print is done on printer set up. If all else fails try the manual it usually has a troubleshoot section. Oh yes make sure you have the correct usb port some are configured at a lower level ( mine has 2 different ones a 2.0 and a 3.0 the 3.0 is blue when you look inside of it) my 2.0 port wouldn't set up my printer I had to use the 3.0 port. Hope it helps you some!
Feb 15, 2013 | Canon Pixma iP6000D InkJet Photo Printer
IT WILL NOT PULL THE PAPER INTO THE PRINTER
Feed guide roller worn, or not making contact with paper in the path, or failed microswitch that detects the paper and initiates the paper transport process
Feb 10, 2011 | Canon Pixma iP6000D InkJet Photo Printer
Ihave a canon pixma iP6000D want to mirror image
Download some free software, the "GIMP" (Graphic Image Manipulation Program) from http://www.GIMP.org and use it to "flip" your image.
May 30, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Paper Jam and i do not have one. Help
Hello sir; On the paper exit unit there have a paper exit senser got to be stuck or out of track. loose it or put it back in right position.
May 18, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Power led blinks - canon pixma pro9000
Your canon printer needs to be serviced. That error is treated with special lubricant applied to a cam assembly inside and above the sheet feed assembly.
Mar 22, 2009 | Canon Office Equipment & Supplies
Sir iam using cannon pixma 1p6000d photo printer , when i try to switch on my printer i am getting error message error code is 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon ip6000D
hi,
use good quality paper for printing. clean the feed roller or get the printer serviced from the authorized dealer.
thanks
Aug 09, 2008 | Canon Pixma iP6000D InkJet Photo Printer
I have a Canon Printer.. Pixma iP6000D. I am trying to print out pictures. But everytime I try to load in my 4x6 glossy paper, the printer does not pick it up. I keep getting an Error to load paper. Is...
You do know that you can use 4 x 6 photo paper in the paper feed? or else you have to tuck it into that little try under the printing outlet and be sure to click the change of feed button on the upper right of the console.
Mar 19, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
269 people viewed this question
old marine
old marine
