Question about LG Televison & Video
I have a 52SZ8R-TB it keeps switching off and the red light next to the green on light stays on can you please solve this problem for me step by step
    Top Expert:
  • LG Master
  • 75,471 Answers
Hello
It is the power supply regulator board problem. You must have a digital multimeter with frequency counter and soldering iorn to preceed the work. you must have some experience in servicing digital electronic boards. Be patient and beware, as you are to work with AC mains supply board, and should wear a gloves.
Approach the power regulator board, can be easly located as power chord goes to a small board inside which contains some filter chokes and after spike filtering it comes to the main power baord [MB-03CA]. Find the P841, a connection comes out from it, which contains 6 connections, which in turn supplies voltage for the fan and [2 pins], other two of them will be marked GND and an other one [S12V] and the end pin marked [PWR]. this PWR pin will be connected to system control section, and is meant for power On. and Power Off.
Check the voltage at this pin while power is on to tv, and make the power OFF and On with remote control. The voltage at each press of the power button on the remote control should change voltage at this pin to High [5V] and Low[0V]. this is the first check you should do. Be very careful, as all the parts in that board are Live and dangerous to touch.
If this test is Ok, come towards [P821A] on the same board and measure the voltages at it [11 Nos] pins. I'll give you the voltages that should be at these pins here. Pin1=ground. pin2=17V. pin 3=11v. pin 4=ground. pin 5=ground. pin 6=ground. pin 7=ground. pin8=4V. pin9=4V. pin10=ground. pin11=7V.
If any of these voltages are found abnormal or none at all, the power inverter board should be replaced with a new one. There will be specifications and number on the print side of that board and should be noted when order for a new one.
First of all, unplug and replug these to connections. if there is any loose contact have between connection, this process will set it right. If not replacement of the power board is recomended. OK.
Posted on Mar 19, 2011
LG 52 in DLP 100.1 Model 52SZ8R - TB keeps turning itself off. Can you help?
i am having same problem did u find out why it does that ?
Aug 07, 2010 | Televison & Video
I have a LG 52 inch model number 52SZ8R-TB but no longer have the manual. There are 3 red LED's on the front panel, the right one flashes red whenever I try to turn the TV on. Does anyone know what this...
YOU CAN REVIEW THE MANUAL FROM THE FOLLOWING LINK.
http://www.lge.com/au/support/product/support-product-profile.jsp?customerModelCode=52SZ8R-TB&initialTab=documents&targetPage=support-product-profile
Dec 11, 2009 | Cars & Trucks
Reset globe meter
Press ok on the TV and mute on the remote at the same time about 6 seconds) to bring up the rest menu
Apr 17, 2009 | LG Televison & Video
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
Lg llp xg22 lamp reset
These instructions are taken from page 44 of the User Guide.
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Aug 02, 2007 | LG LP XG2 Multimedia Projector
Televison & Video Logo
44 people viewed this question
Computer Repairing
Computer Repairing
