Question about Pulsar Watches
Need to move time to spring forward 1 hr on Pulsar watch 2003
SOURCE: Pulsar Analogue Ladies Watch - no calendar
Replaced the Battery.
Posted on Feb 23, 2008
  • 2501 Answers
SOURCE: my Oceanus watch model no. 4749 stays 1/2 hr slow.
You can get manual information from the Oceanus web site (NOT casio strangely enough!).
Insert "www.oceanus-us.com/" into your search engine
Select "support", then "Manual information"
Enter your model number and download the information. There are instructions on choice of home city and further adjustments if it still is not correct after initial setting up.
Posted on Jan 17, 2010
  • 2501 Answers
SOURCE: casio G-Shock what buttons to change time. need to
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Mar 17, 2010
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Posted on Mar 25, 2010
micromatikal
  • 2777 Answers
SOURCE: Need instructions on how to
Some of these can be quite a bugger to set, there are so many variates of Pulsar watches, and I'm not able to locate exact instructions for that model. However if you call Pulsar with that model number they will gladly provide a free manual for you, one you can probably even download and view, or they can email it to you directly. Please call Pulsar at 1-201-529-5730 and request the instructions.
Thanks
Tim
Posted on Sep 23, 2010
I have a Pulsar watch need to change to day light saving time
just put the hour hand forward or back 1 hour
Mar 15, 2016 | Pulsar Watches
Pulsar Chronograph 100 m - The second hand on the left small dial (not the sweep second hand of the stop watch) has begun moving erratically. It appears to move for two counts and pause for three and then...
If your watch is solar powered the second hand performs this characteristic when it's in need of a charge. Try placing your time piece under a bright light for short time or in direct sunlight and see if this helps you with your problem.
Jul 21, 2011 | Pulsar Chronograph Watch
I've lost the owner's instructions and need directions for setting the alarm.
  • Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
  • 2 Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
  • 3 Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
  • 4 Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
  • Aug 20, 2010 | Pulsar PXH225 Watch
    Casio G-Shock what buttons to change time. need to spring forward 1 hr.
    Accept terms
    Mar 16, 2010 | Watches
    The hour & minute hands on my pulsar nx14-x001 do not move. the second hand quivers, but also does not move. the digital time and other functions are okay. HELP!
    Without knowing the model of the watch i would say you need a new battery. It is typical for this style of watch to have two batteries or one lithium battery. In either case the analog movement will drain faster than the digital portion of the watch and will stop working first.
    Sep 21, 2009 | Pulsar Watches
    Changing from 24 hr system to 12 hr system
    • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
    • Make note of the hour if you don't have another clock handy
    • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
    • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
    • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
    Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
    Set time on Fossil DQ1138 Watch
    Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
    Apr 01, 2009 | Fossil Digital Sport Hologram Display...
    Setting model number jr3060-59f
    1. set mode to CHR with the bezel fully in.
    2. pull bezel out 2 notches. This will set all (or most) hands to 12.
    3.press A (top button) repeatedly until you get MIN in the left window
    4.turn the bezel to move the min hand forward.
    4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
    5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
    Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
    Watches Logo
    Top Pulsar Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Pulsar Watch Expert? Answer questions, earn points and help others
