Question about Westinghouse Electric Refrigerators
Fridge / Freezer RS662 - Fridge lower door hinge attachment damaged, looking for full Door to buy.
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
SolutionGuy
  • 331 Answers
SOURCE: Fridge door will not stay shut
Glenn,
Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
Posted on May 26, 2009
erpaalai
  • 999 Answers
SOURCE: one door lower than other, how to adjust door
The door can be adjusted with shims on the hinge post or by adjusting the cabinet by raising the front corner opposite the higher door. Keep in mind the doors are not designed to be perfectly even.If the difference is the depth of a quarter or less it is good. The seals making good contact all the way around is more important. Eric
Posted on Aug 08, 2009
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
SOURCE: How to adjust fridge and freezer doors on Kelvinator C520 Litre
how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
Posted on Nov 12, 2010
I removed the freezer door and now I cannot reattach it.
Generally you just reverse the removal process. Place hole in door bottom over lower door hinge pin and place door in closed position. Insert top hinge in top hole---align hinge screw holes with holes in fridge cabinet and insert screws. Not sure what is giving you the problem. If you need more help post back brand and full model number so I can look it up.
Apr 21, 2015 | Refrigerators
How do i fit the door on the other side
If you look at the opposite side of your refrigerator, you'll find one or more plastic covers which can be removed to expose mounting holes. You have to remove the doors from the current mounting position, remove the hinges and transfer them to the other side, install the doors and you're done
Jan 25, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
I have a full length fridge and the door seems to have dropped about 1/4", causing the door to bind at the hinge and catch against the adjoining unit on the closing side. What do I adjust and how...
sounds like lower hinge loose or bent down or plastic washer wore out remove top hinge and either move bottom hinge up or shim with washer to raise door
Feb 03, 2018 | Liebherr European Right Hinge Fully...
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Freezer door will not stay closed when closing refrigerator door
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
To replace it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Sep 04, 2009 | Refrigerators
Suddenly our GE side-by-side fridge door doesn't shut
Check the bottom of the freezer door at the hinge to see how it is suppose to look and work, assuming the freezer door still works right. Then look at the ref. door and compare.
Sounds like something is broken or damaged. Usually there is a white tefflon washer which is beveled to allow the weight of the door to help it close. Check with an appliance parts store, you may be able to buy just the washer or the whole hinge assembly may come in a package.
Jan 25, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
94 people viewed this question
Top Westinghouse Electric Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Electric Refrigerator Expert? Answer questions, earn points and help others
