Question about Sunbeam Humidifiers
Can't find the filters Wick HWF75/SF221 I bought it at WalMart and they never carry the filters. This unit takes one a week - they run $10.00 each and this gets pretty expensive. Any information you can give me would help, especially where I can get the filters. Thanks, Melissa Graves
3 Suggested Answers
barterjoe
  • 344 Answers
SOURCE: Bought H12 series evaporative humidifier.
If you say you have hard water then yes expect to change the wick more often. As the heavy elements are left in the wick the wick becomes less able to hold water. You might try the product CLR, which I am sure you have used before if you have hard water. I have used strong vinegar to clean them too. You just need to clean the calcium and minerals out of the wick and it should be up and going again. This is assumong you don't have a special material that the CLR will eat ;)
Using Pure/distilled water would help.
Good luck
Posted on Feb 25, 2011
  • 4736 Answers
SOURCE: Bought from Walmart in Lethbridge,
You may purchase new filters directly from Holmes Products website
http://www.holmesproducts.com/Filters.aspx?cid=1610&page=-1&gclid=CKys-rPLpqcCFQ975Qod82UqAA
Posted on Feb 26, 2011
Fan won't run. New filter and wick. Why won't the fan come on?
work switch back and forth a few times . sometimes they seem to gum up over summer
Feb 06, 2015 | Humidifiers
What if i run out of filters for my vicks
i have one of these. walmart carries them. also f they are out, which i've never seen them out of these, try ebay. they carry everything
Oct 08, 2014 | Humidifiers
Package indicates wilter might need to be chaged once a season
You should probably follow the directions in the instruction manual, which do say how often to change it. If you wish to risk a moldy house or an unproductive filter you can use it longer than advised. I soak mine in 50% vineger 50% water for an hour to dissolve mineral deposits and kill fungus, so the wick doesn't become too clogged to operate. I believe this lets it last a few times longer, but it is a Honeywell model of filter and I don't know how that would work on your filter.
Mar 06, 2014 | MoistAIR Genuine MAF-1 Wick Filter
How do I change the filter on Sunbeam Model SCM 2412 humidifier?
Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
Nov 03, 2010 | Sunbeam (0013871361) Humidifier
I have two questions. How do I properly clean my humidifier and recently it has started coating my furniture with a white powdery film. Why has it started that?
there is some cleaning tablets you can use periodically called protec beads ... cleaning can be done using high acid vinegar soak .. then hydrogen peroxide can be used on any mold .. this unit as well as ultrasonic type models will put out calcium dust if your water has calcium added or is hard water .. calcium is often added to water to give it a good taste .. one way to keep the unit clean for a long time is to use only distilled water .. and make sure there is no calcium added .. (read the small print on the container) .. its hard to clean the fan chamber in this unit .. lots of people complain about the dust .. the wick/filter type humidifiers dont put out dust but the calcium does accumulate on the wick/filter .. so you have to change that frequently (6-9 weeks) .. yours doesnt have a wick but still needs cleaned regularly ..
Sep 26, 2010 | Vicks V4500 1 Gallon Humidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
How do you change the filter in a holmes cool mist
http://www.jardenstore.com/manuals/MANUALS/HM1865-U_43_74701759.PDF
here is the website for the manual. when you download it go to the maintance section and it will let you know. if not. basically all you have to do is turn off your unit first. take the base and the tank off take out the wick filter disgard and put in new one. put everything back and turn on unit. and it should would like new
Aug 15, 2009 | Kaz 3300 Humidifier
Bonaire BCM-645
1. Turn the unit off and disconnect from the electrical outlet.
2. Remove the reservoir from the housing.
lock knob to the unlocked position
place.
10.Fill the reservoir and place back into housing.
11.Repeat Operating Instructions It will take about 30 minutes
for the humidifier to reach maximum output. You
can purchase replacement filters (model BWF100 filters)
at your local retailer, by calling 1-800-253-2764, filling
out the accessory card, or by visiting
www.bionaire.com. It is recommended that a
replacement filter is purchased for uninterrupted use.
Here is a link for the manual for your humidifier:
http://www.appliancefactoryparts.com/content/pdfs/117223.pdf
Good Luck.
Apr 24, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
Quiet Comfort 42-14411
Those filters don't last forever! Whenever I had that problem, I just replaced the filter. (The fresh filters also contain some kind of anti-bacterial or anti-fungal, since you're not supposed to add anything to the water which would spray into the air.) My problem has been finding new filters--does Sears still carry them? (The small one I was in recently does NOT.)
Nov 12, 2007 | Kenmore 14410 Humidifier
Humidifiers Logo
998 people viewed this question
Top Sunbeam Humidifiers Experts
Oloyede Monsuru
mike
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
