Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
Hi, I have a jet 3 ultra chair . I have just put new batteries on and can still only do about 4 miles from a full charge, any ideas, Many thanks Rolfe
  • 692 Answers
Rolfe could be a couple of things check the brushes in each motor for excess wear and check to see if the motors are getting overly warm after driving for awhile if they are then you could have a brake problem on one or both of the motors. If your brushes are less than 1/8" long then they need replacing and you can have a provider order some from Pride for you or have them service the motors for you. If it is the brake then it will have to be replaced by a tech who knows what to do if you can get the brake from Pride. Now I'm not suggesting this or recommending this because of safety and liability issues but you could remove the brake from the rear of the motor that is getting hot (if it is) leaving the wiring connected and hang the brake in the rear of the chair so it won't break the wiring and drive the chair to see if that makes a difference. If you remove the brake and wiring then the chair won't move at all because the controller is looking for the brake when you turn on your chair if the wiring is disconnected you will get a fault error and the chair won't move. Also have someone load test your new batteries just because"new" doesn't mean good and a weak battery will reduce distance driven. Hope this helps
Posted on Mar 19, 2011
Testimonial: "Fast response will try ideas thanks "
How long can i run chair on one charge'
With new, fully charged batteries, you can get a good 8 miles at full speed with a normal weight load on the chair. The chair goes about 4-5 mph, so an hour and a half or more at full speed on level terrain. Be sure to always recharge daily, keep the chair on the charger when not in use(batteries will die if you don't)and avoid running the batteries all the way down....try to stay in the top 2/3 charge range and you will get more life.
Apr 27, 2014 | Pride Jazzy 1103 Ultra Indoor Power...
Why won't my jet 3 ultra wheelchair run even after installing new batteries?
Batteries are not put in right. the charger is also bad. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 15, 2014 | Jet 3 Ultra Power Chair
I have a Jet 3 power chair. I recently had 2 new motors and batteries installed. I am having problems with the batteries holding a charge. I charge them every night for 10+ hrs. It shows full charge in the...
yes there is a short either in the motors or joystick u would be better off contacting the dealer and have a tech run his programmer on it and tell u what is wrong, will save u money if u can take that power chair to the dealers shop
Jan 21, 2014 | Jet 3 Ultra Power Chair
I have my Pride Jet 3 Ultra Power Chair (D504002.04) since 3i/01/09 the battery condition metre is 2 lines red.I plug to recharge the battery but it is not charging. lPlease, may you tell me the...
Isabel you could have battery problems or it could be a charger problem. you would need to contact your provider (where you got the chair and ask them to check it for you) Now Plug the charger in for a couple of hours and look at the light on the charger (it is located under the rear of the chair) if it is green then it indicates a full charge if you have no light then it could be that the batteries are getting the charge or the chharger is not operating A tech will haveto determine the problem for you. Sorry I couldn't give you a instant fix Hope this helps
Oct 31, 2010 | Jet 3 Ultra Power Chair
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
How many miles will the chair travel on a full charge?
If the batteries are new and fully charged - 10 - 12 miles.
Aug 08, 2009 | Jet 3 Ultra Power Chair
I can fully charge the Chair and my battery lights will flash Red after about a mile.. I have fully drained the batteries and when I plug the Chair in, the Meter goes to #4. the Meter has 1-6..
It sound like your batteries need to be replaced. how old are they? The battery life eventually dwindles down to almost nothing it says its full because it is full to its capacity however it's capacity has depleted.
Jun 23, 2009 | Jet 3 Ultra Power Chair
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
183 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
