Question about JVC HD-61FH97 61" Television
I was watching tv and i heard a loud click then the screen turned black. the button in the front to turn on the tv kept blinking. I tried to turn it back on and it seemed as if it would then another click and the button in the front blinked again. Is my problem the lamp?
  • JVC Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 18, 2011
Samsung plasma screen went black. Was watching tv, heard a loud pop and the screen will no longer turn on. You can hear the tv turn on but no picture. Power is still working, just a blank screen.
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
Jul 28, 2017 | Samsung Televison & Video
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Sony KDL-46S5100 As the customer was watching it he heard a loud crackel sound and went dead. now all it does is click when I press the power button. No Bad Caps. Any suggestions? Thanks. Alltech TV Repair...
Let me know does power light is blinking on KDL-46S5100 tv front when it refuse to turn On?
If yes, how many times it is blinking as there would be 3 seconds long pause between blinks so count pause to pause and let me know to diagnose possible cause of problem and provide you its solution.
Thanks.
Nov 15, 2010 | Televison & Video
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv was working went off LAMP flashing and would not come on.
Lets go back to the beginning... What were the original symptoms? Was it just the clicking or were the lights on the front of the set flashing too? With the new lamp, is there any thing else other than the clicking? If not, then the problem is likely to be the ballast. The clicking could be the lamp attempting to "fire". With a defective ballast, the lamp won't fire and the set won't come on. If you choose to replace the ballast, DO NOT use the old lamp. It is relatively common for a defective lamp to smoke the ballast under certain conditions. Also, it is possible that the original cause was the ballast that failed and took out the lamp with it.
Please keep us posted.
Thanks,
Dan
Jul 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV acts like it is turning on then shuts off then repeat, repeat
When my lamp died the bulb literally exploded. That may be what you heard. Have you check the lamp? If the lamp is ok, the lamp's ballast or power supply might have blown.
May 22, 2009 | Toshiba 62HM95 62" DLP HDTV
Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Jun 15, 2007 | JVC PD-42V475 42 in. HD-Ready Plasma...
JVC HD-61FH97 61" Television Logo
94 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
