Question about ASUS M2N68-CM (90-MIB5K0-G0EAY0GZ) Motherboard
Desktop cp with win 7. asus m2n68-cm motherboard dual core ddr2 ram 5200 cpu 400wt psu Have a prob to start windows on first all is ok.When i reboot it will try then stop and stay in this loop only way out is to power off at main. After about 5-10 minutes will fire up.Does not do this all the time but wound like to fix. Is there a Solution guy's
    Master:
  • 525 Answers
Put your windows 7 disc in boot from it and do a startup repair.
Posted on Mar 18, 2011
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
I can't Enable audio after instaling window 8
Sound like you lost the driver or is not compatible. Here are your specs and downloads. The newest one is for Win 7, but it's worth the try. It worked for me.
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#download
Sep 23, 2012 | ASUS M2N68-AM SE2 Motherboard
M2n68-cm asus ddr2 ram. the first boot was fine i turned it off 2nd boot starts to load then turns off stuck in this cycle
First you have to make sure all of the wires are plugged in properly. Many times this problem occur because a wire isn't properly secured. You can also try resetting the bios options to 'default settings'.
Mar 17, 2011 | ASUS M2N68-CM (90-MIB5K0-G0EAY0GZ)...
Hi. I get a blue screen with bad_pool_caller error, xp pro starts and stops and then blue screen and reboot forever. Is the motherboard (ASUS M2N68-AM SE2) in default. AMD PHENOM QUAD CORE CPU temperature...
Dear mariolama
It can be due to error in any newly installed hardware or software.
Most probably due to RAM. Check your RAM is perfect or not in other system. Or clean it and restart the system and check.
Reply me the status
Thank you for using FIXYA
Mar 14, 2011 | ASUS M2N68-AM SE2 Motherboard
Please suggest a graphics card for ASUS P5KPL-CM motherboard, my budget is 200 - 240$ and have 400w PSU. earlier I had Nvidia Geforce 9800gt installed in my pc, but it has damaged. I have Intel core 2 duo...
hey there,i reccomend the gts 250 as it is exeptionally brilliant..
heres the link:http://www.amazon.co.uk/PNY-Technologies-nVIDIA-GTS250-Graphics/dp/B001V9FA6I/ref=sr_1_2?ie=UTF8&s=computers&qid=1296670576&sr=8-2
Regards,Finphillips Please Rate me
Jan 13, 2011 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
Hi, I'm looking for Asus P5LD2-VM Dual-Core CPU Intel i945G chipset drivers that are compatible with windows 7. Please help....thanks for the support.
You can download the drivers from here (click here) or from here (click here_asus official website)
If you need further help, let me know with the name of the operating system installed on your computer.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | Ld Asus P5LD2-VM Dual-Core CPU Intel i945G...
Product comparison
deal 2 is definatly better, go for it
Oct 28, 2008 | Computers & Internet
Brand new motherboard wont start up
try taking 1 stick of ram off the motherboard, and boot up with 1 stick in slot 1 or 2.
You should get some beeps, 1 is system Ok.
3 is usually RAM/Graphics problems.
Also try booting with the motherboard setup disk in the CD Drive, it may be looking for files to initialise the Board.
And the obvious, check that all cabling is correct from mainboard to front panel. Power on/off Reset et,c.
View the user manual to see if the board has any jumper/dip switch settings for different configurations.
Mike @ compurepair.
Mar 14, 2008 | Computers & Internet
ASUS M2N68-CM (90-MIB5K0-G0EAY0GZ) Motherboard Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
