Question about Intel Computers & Internet
I have an intel boxdg43gt motherboard and my buddy went and changed the RAM voltage in the bios how do i change it
  • Intel Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
Posted on Mar 18, 2011
How do i change the memory bus speed on my dell optiplex 170l? The CPU is an Intel Celeron 2.4GHz. The mother board processor speed is 400MHz and the Bios indicates a memory bus speed of 266MHz and does...
You checked in the right place as far as looking in the BIOS, however, memory and CPU sockets do not necessarily have the same buss speed. My FSB runs at 1066Mhz and my RAM at 800Mhz, it all depends on what type of RAM you buy as to the bus speed. You can up the bus speed on your RAM if you wish to reduce bottle-necking, but I've only done that a few times. In order to adjust anything, you must set the settings to manual. Be careful when you change this stuff around though, voltages must also be adjusted accordingly.
Feb 28, 2010 | Dell OptiPlex 170L PC Desktop
Help Finding The Best CPU For P4SD-VX Motherboard.
Brilliant, I commend you! I've posted using the simple CPU-Z program to several people on here, and they just don't seem to get it!
Sony doesn't release detailed info on their motherboards, for the most part. Just the usual generic info.
2.6 Volts?
Open CPU-Z again. CPU tab.
Let's see if you have this processor.
Name: Pentium 4 HT 2.6C
Code Name: Northwood
Package: Socket 478
Technology: 130nm
Core Speed: 2600.0MHz (Fluctuates when the computer is running)
Multiplier: 13X (Fluctuates when the computer is running. When the Core Speed fluctuates enough, the multiplier changes to match)
Bus Speed: 200.0MHz
Rated FSB: 800.0MHz
Voltage: 1.475 to 1.525 V (Fluctuates)
Click on the Mainboard tab.
Is the motherboard chipset Intel 865PE?
[Chipset: Intel i865PE
Southbridge: ICH5 or ICH5R
Motherboard made by Asus?
It may not have an Auto CPU feature in BIOS Setup then. Means you cannot just put any old processor in there. Have you been into your BIOS Setup yet?
SPD stands for Serial Presence Detect. This is used by BIOS to automatically detect what ram memory is being used, and the ram memory timings.
JEDEC was Joint Electron Device Engineering Council/s. Changed to JEDEC Solid State Technology Association.
One of the things they have done is to set standards for Ram Memory.
Voltages used and ram timings.
JEDEC 1 is the ram memory module, in Slot 1 on your computer.
(May state DIMM 1 on the motherboard)
JEDEC 2 is the ram memory module, (Stick) in Slot 2.
JEDEC set the voltage standard for DDR Sdram ram memory, at 2.5 Volts. Your computer has DDR Sdram ram memory in it.
The default voltage setting from the factory will be 2.5 volts for your computer.
Nov 16, 2009 | Office Equipment & Supplies
I have intel board d-815 with intel logo. this board hangs at the time of setup entering. i have used all of my techics like power supply change, battery cell change, processor change, ram change and also...
they best way is to flash ur bios that will really help u can visit the intel website and download latest bios for your motherboard and flash and install it using according to instructions.thanks
www.intel.com
Mar 31, 2009 | Intel Desktop Board D845WN Motherboard
My Intel D102GGC and Mercury 915GLV motherboard not wake up
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
Mar 06, 2009 | Intel D102GGC2 Motherboard
Intel 845GVSR Motherboard no display Problem
no diplay in this board give me sme notes to chag ic.what ic i did change
Jan 23, 2009 | Intel Motherboard
Intel 845 mother support
research the ram to see if it will work on that motherboard. some ram requirements are present when you get memory for a pc. not all ram are compatible with certain motherboards.
Oct 02, 2008 | Intel Motherboard
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Computers & Internet Logo
55 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
