Question about Xerox 5500/DT Laser Printer
Xerox 5500DN Phaser PCL driver installed and printer and IP recogized with web printing Prints setup and help info from printer panel pefectly Paralell or IP printing from PC Host only dumps hex output with no image or text This printer was donated to our church for use in the business office and I'm at a loss on how to remedy the printer. Any ideas on what I'm missing or doing wrong?
  • 3 more comments
  • rbaklini Mar 19, 2011
    Dumps hex whether connected to LPT or IP.
    Downloaded drivers from Xerox.
    Already removed/reinstalled drivers same results.
    Other ideas solicited.
    I'm requesting definitive info. I downloaded the drivers, read the manual and candidly stymied. I'm quoting your thread:
    Also a good idea to download the documentation for the printer such as the user and installation guides which should help you figure out what is going on....
    So why am I paying for experts?
    Please undestand, I've read the manual, downloaded the drivers the OS (XP) likes, connected the printer both via paralell and IP. The printer works great when printing from the interface. Dumps hex when printed from an application or OS. There are 4 pages of setup and I inherited this printer. Looking for definitive and conclusive answers. At a directed request I will send the setup info.
    Thanks in advance for providing tribal/expert info on the Xerox 5500 Phaser
    Thanks Splines -- yes I received and performed suggested tasks with no resolution.
    Please send to another FixYa consultant
  • Xerox Master
  • 12,061 Answers
Hi, this is often a simple driver problem. Try this, go to a PC that you wish to print from, Obtain the Driver and any software for the exact make model printer you are using, now install that on that PC, follow any instructions issued, install as a networked printer.
See no matter what, all PC's need to have a driver/software (Usually on a CD/DVD that came with the printer, or down-loadable from the Manufacturers website) installed for the printer concerned, then connect to that printer & test.
Now to check, go to INSTALL A PRINTER, select, Networked Printer find your printer and select it connect to this printer, it may/should perform some tasks, you may even be asked for a driver, whatever, show it where those files are, and proceed, now after it is all OK, try to print a test page, all should be OK.
If not, restart printer restart PC, try setting it all up from the start again.
You must do this on each and every PC you wish to print from.
Posted on Mar 20, 2011
  • 345 Answers
If it is printing kinda scrambled it is because of a driver. The driver you downloaded does not have proper language support to be able to print in our language. When i used to work as an it PLC would work in most cases but some times we would get same stuff as you and we had to install PCL5e drivers. This link has all the drivers for this printer. I would try the PCL5e and see what happens.
http://www.support.xerox.com/support/phaser-5500/downloads/enus.html?operatingSystem=winxp
Now this driver is for XP so not sure is this what you need it for. There is a drop down towards the top and gives you other drivers also if you need them.Hope this helps.
Posted on Mar 19, 2011
    Sergeant:
  • 236 Answers
The printer is printing in hexadecimal the binary data it is getting over the network as it does not recognize the print stream correctly. Likely reason is that the print stream originator which would be a PC trying to print to it is using the wrong driver. Could try connecting the printer directly to the PC in question and installing it as a local printer then trying to print to it directly. If the result is still a hex dump, then the drivers are incorrect. Usually the drivers not only have to be the ones for the printer but also must be tailored for the PCs operating system as well. If you can get the correct drivers for the PC and can get it to print correctly on the Xerox, then the Xerox can be reconnected to the network and re-installed as a network printer (delete the old network printer first) on the PC. During the installation of the network printer on the PC, do a final test print to check.
Posted on Mar 18, 2011
  • 4 more comments
  • Bill Yee Mar 19, 2011
    Here's the link to Xerox web site for Phaser 5500 Drivers & Downloads...
    http://www.support.xerox.com/support/pha...
    Note that I had selected the Windows XP operating system. To be safe, you should select the appropriate operating system before each download of the driver. It is probably the same one.
    There is quite a lot of documentation available which you may want to download as well...
    Because the printer was donated, it is possible that the printer has been setup to emulate some other kind of lase printer. Should be able to check this on the printer's panel. If it is emulating another printer, then need to use a driver that is for that printer. Also a good idea to download the documentation for the printer such as the user and installation guides which should help you figure out what is going on....
    Just to make sure you got this...
    1. download the user / installation guides if you don't have them as they may help you resolve.
    2. check panel that the printer is not emulating some other printer - if it is then you need other driver
    3. do a successful local lpt print before trying it as a network printer
    Just trying to help you and the money is totally secondary and up to you to pay only if you feel you have gotten any value. I feel humble enough to say I'm not familiar with the particular printer you have but have set up and used HP Laser printers as well as Brother Laser printer. Anyways, have to go for supper now... Good luck with resolving your problem.
    If you can post the detailed set up info it may help. Will take a look for it later this evening and post a comment one way or the other. Sorry couldn't help you out at this point.
  • Bill Yee Mar 21, 2011
    Not seeing the printout dump, it is difficult to even guess as to what might be the problem. The assumption is that it is a driver but it could be at a higher level since 5500 is postscript printer and the dump could be from a postscript error. To further your understanding of this, please copy the following link to browser's address field to go to the Xerox's Phaser 5500 Support Knowledge Base web page "Prints Gibberish or Garbled Text, Offending Command or PostScript Error" http://www.support.xerox.com/SRVS/CGI-BI...
Hi i have Xerox 7760DN with both ps anc pcl enabled - there's a 68 page document getting prited everytime the printer is turned with bunch of gibbersih from startup. DO you know the resolution for
Sounds like a print job was sent to that printer using the wrong print driver. Unplug the printer from the network and see if it only prints the startup page. If so, then you need everyone to cancel the print jobs they sent to this printer. Then hook the network cable back to the printer and see if a print job can be sent to it (one that has worked in the past). I suspect someone has an old printer driver that is using this machines IP address to print to and it is confusing the Image Processor Board...
Apr 04, 2013 | Xerox Phaser 7760DN Laser Printer
Phaser 8560N prints multiple pages when powered on
This was due to the TFTP (PXE) setting on the printer set to on. No more wasted paper at startup/wakeup after changing setting to off.
Jan 12, 2010 | Xerox Phaser 8560N Laser Printer
When I print jpgs with the Xerox Phaser 6180, they print with a pink box around them
Have you tried loading a different print driver? I know the PS Driver is recommended for a phaser, but see if they have a PCL 5 or 6 and see if simply replacing the driver resolves the issue.
Dec 29, 2009 | Xerox Phaser 8500/DN Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Phaser 3200 only printing code, not actual document
Try downloading and installing a PCL language driver from the Xerox.com site for the phaser 3200. It looks like that could be a PostScript issue. Installing the right driver is very important anyway. If that does not help, try and copy paste the document in a new document and save first as the old document could be corrupted. If this does not help either lemme know and I think of something else.
Nov 11, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Sep 27, 2008 | Xerox Phaser 7300DN Laser Printer
Distorted image printing from InDesign to Xerox Phaser 8560
Have you tried a different driver? Most of those phaser printers have a PS driver loaded, See if there are PCL drvers for that product, and try that. I went on the Xerox.com site and they have both PS and PCL 6 and PCL 5 drivers, I believe one of those will help your problem.
Now that being said, If you are getting the stretching on other programs, then the problem is the drum motor encoder is getting contaminated with silicon lubricant from the maintenance kit. That will cause that problem, But since you are saying it is with one specific program, I suspect a different driver will correct the problem.
Sep 26, 2008 | Xerox Phaser 8500/DN Printer
Phaser USB Disabled?
See if you find the settings you need here.
If you do or Do not, let me know and I will send more info.
Phaser 7700 Printer: Enable and disable protocols
  1. With Menus highlighted, press the OK key.
  2. Scroll to the Network Setup menu by pressing the Arrow Down key.
  3. Press the OK key.
  4. Scroll to DHCP/BOOTP, TCP/IP, EtherTalk, NetWare, IPP or CentreWare IS by pressing the Arrow Down key.
  5. Press the OK key. Pressing the OK key will set the protocol to either off or on respectively.
  6. To exit the menu system, scroll to Exit and press the OK key.
Aug 14, 2008 | Xerox Phaser 7700 Laser Printer
My 8500N prints reams of code instead of the jpg sent to print
First off and I am sure you have tried this, but power of then power up your printer. Just to allow it to reload the software internally.
The other thing is to change drivers. That is what is generating the code.
You can go to Xerox.com there is a varity of drivers to try. Sometimes a PS and PCL driver will intrepert differently and print code like that.
Not sure preview is where the problem is. But I am assuming it prints fine in other applications.
There is also a firmware update on the xerox.com site, you can upload the newest printer software there. Or at least start out with a clean version on your printers operating software.
I strongly suspect a driver change will help.
Mar 01, 2008 | Xerox Phaser 8500N Printer
PCL PC-864
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=4500&Xlang=en_US&Xcntry=USA&source=XOG&prodName=Phaser%204500 Here is the site you need. They have a web based pcl driver update. Good Luck, Tim
Mar 05, 2007 | Xerox 4500 Laser Printer
Xerox 5500/DT Laser Printer Logo
178 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
