Question about KitchenAid KAWS850L Top Load Washer
Intermittent spin cycle (clothes sometimes still wet), Changed the motor and coupler already from blind advice of not seeing any oil on the floor (costly mistake). Second assesment discovered tacky oil on the gearcase and splattered on the drain hose and other components (however not on the floor). Posts indicate transmission and/or clutch, scared to make a second mistake. How can I determine which one is bad? Model # KAWS750JQ4
  • 3 more comments
  • ricci708 Mar 21, 2011
    I bypassed and removed the lid switch years ago. The drum does spin, only very slow, I really don't hear any funny noises.
  • ricci708 Mar 22, 2011
    The drum does spin, it doesn't spin fast enough to dry the clothes. What are your thoughts on the oil on the gearcase?
    Items # 12 and 13 are listed as:
    12-389140 Block, Basket Drive
    13-383727 Gasket, Centerpost
    How would I check to see if they are bad? and if they are would the drum turn at all? I do get a slow spin.
  • ricci708 Mar 25, 2011
    Daniel,
    The video you sent is very informative and a great how to guide, however, I would like information on narrowing the problem down by determining if thye problem is the transmission or the clutch. I already made a one mistake, I don't want to make a second. My symptoms are that I do not hear any funny noises, there is some oil slatter on the gearcase and surrounding parts, the drum spins slowly causing the clothes to be wet and sometimes it works correctly.
  • ricci708 Apr 13, 2011
    Daniel,
    I changed the transmission, it seemed to work, however when the drum was spinning it appeared to achieve top speed and I was able to stop the drum with little to no pressure with my hand. I than ran a wash with clothes and it does not dry the clothes. What else can it be? I changed the motor, coupler and now transmission.
  • 4,323 Answers
Hi
What about the lid switch, have you already checked that? You can try to jump start the switch by removing that switch and then connecting its two wires together, if the washer spins then replace it, if not then let me know if you hear any noises and the model no and how old is this unit. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 18, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 21, 2011
    Years ago.... :)...if it was really years ago then do it again to check that....if it wont spin and you doing hear any noised then check the clutch assembly, it does not indicate a transmission failure. If bad it should be replaced.
  • Daniel Scott
    Daniel Scott Mar 22, 2011
    Hi
    Oil on gear-case is not good if it is in very high quantity, however a few drops of Oil are fine. Also, check part#13 (Directional coupling) in below schematic. Coupling Kit Is Used Between The Motor And The Transmission On Direct Drive Washers With No Belt. This Is The Newer Version And Is Made With New Metal Sleeves.
    I would suggest you to get a new Lid Switch and install it as it is for safety of user. Hope this helps...Please post back for further assistance.
    Daniel
  • Daniel Scott
    Check this video:
  • Daniel Scott
    Daniel Scott Mar 25, 2011
    Yes thats why I sent that video....it is the gear case assembly that should be replaced
Clothes still wet after spin cycle; water has drained, agitator seems to spin, but clothes very wet after spin cycle
the problem a lot of times when that happens is a broken motor coupler and a coupler is easy and cheap to replace. This video shows how to replace the coupler so watch it to see how to get to coupler to see if its broken.
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler
I hope this helps
Gene
Aug 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The machine will not spinn, the washing is very wet when finnished washing
clothes are wet after spinning this is due to faulty Motor coupler. test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:If it's spinning when you lift the lid, the coupler is fine.If not then the coupler is broken.It has to be replaced;.This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. ----------------------- If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn motor pulley or tub bearing. Replace the applicable component. Thanks.
Sep 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Will not totally spin
Jan 16, 2010 | Whirlpool LSR5132PQ Top Load Washer
My question is: When I first got my washer it
Jan 05, 2010 | Samsung WF337AA Front Load Washer
I have an old model 110.82074110 that is slow int he spin cycle. I believe it is slipping in the basket drive. Is there a way to adjust? Thanks in Advance Larry
Jan 02, 2010 | Washing Machines
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Apr 01, 2009 | Bosch Washing Machines
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Clothes wet after spin
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
El Resorte de la trasmision en inges se llama MOTOR COUPLER
Si pincha aqui y pone correctamente su numero de modelo pede veer directamente los diagramas para instalar el motor coupler.
Si no enacuentra numero de modelo mire: help finding the model number on your appliance?
Aqui siguen en dettalle mas possibiles rasones por su problema (en ingles)
Motor coupler
Aconsejo tambien comprar el manual de servicio aqui
Aqui hay un ejemplo de ingranages for el motor coupler, se montan en el palito donde el motore enchufa con los otros ingranajes:
Agradeceria si pede votar la solucion, posibilmente en azul.
Muchas gracias.
Aug 08, 2008 | Maytag Performa PAV3200
KitchenAid KAWS850L Top Load Washer Logo
83 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
