Question about Compaq Computers & Internet
Hello, I have a Compaq F755LA laptop . I'm trying to format it. I'm attempting to boot from the dvd, but it won't boot. DVD drive is set first as boot options in the BIOS and the Windows dvd is in the drive. BIOS has been updated to the latest version (F.09), but it still won't boot from the drive. Any suggestions? Thanks
    Genius:
  • 1,189 Answers
Hi horashadow, yes I have a 'suggestion'!
"Go back the the "Boot Priority Menu,"
and make 'either the "HDD, Optical Drive or SATA Drive,"
the first {Boot Option}. The Boot.ini file, Master Boot Record file, or the Boot NTLDR file,
will more than likely be in one of these [Devices].
"Give it a try. "I hope it works out for you.!
Take a moment to give a rating for the help, thanks"
Posted on Mar 18, 2011
Will only boot in safe mode won't connect to lan or wireless, locks up after a few mins, ran everything I can to repair..can't access dvd drive to do a complete format any suggestions?
You may need to pull the hard drive and connect to another computer as a external device to format the hardware, but if you can access bios, reset to factory defaults before pulling the hard drive and try again.
Mar 07, 2012 | Dell Inspiron 1545 15.6-Inch Laptop...
Format aspire4736z
Hi there.
To format you will need:
Operating Systems (OS) CD/DVD
Steps:
1) Enter the BIOS when the laptop boots by pressing the Delete key repeatedly.
2) Once the BIOS is open locate the boot disk priority and set prioity 1 to the CD/DVD drive, set priority 2 to the laptop's hard drive.
3) Save changes to the BIOS and exit. The system should now reboot.
4) Insert your OS CD/DVD.
5) Press Enter when the system asks you if you want to boot from the CD/DVD.
6) The OS setup should now start, the first thing it will ask you to do is format your hard drive.
7) After you drive is formatted you can either continue with the setup and install a fresh copy of the OS or you can exit leaving the main drive clean.
~ Slasher_X
Sep 25, 2011 | Computers & Internet
How can i format my computer
insert a CD/DVD copy of windows into your disk drive, then just follow the online screen guide.
You must first set your bios settings, the first boot should be the CD/DVD rom drive then your hard disk. Re-start your PC and press any key once it show during command prompt display.
Hope it helps..
Sep 09, 2011 | Compaq Presario Notebook
Laptop is not detecting the CDs or DVDs
check your CD/DVD driver is properly installed. you can check it by going in control panel, Clean your CD/DVD drive by any Cd/DVD cleaner.
Jul 06, 2011 | Compaq Computers & Internet
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Windows unable to complete format.
How did you format the computer, inside windows or outside?
Try this change the boot sequence from the BIOS instead of booting first to HD make your optical drive as first boot. After changing the boos sequence insert the windows vista disk to the drive then restart the computer. When it boots it will ask you to press any key to boot to CD/DVD. Keep tapping on space bar. If you notice it will say windows copying files. When copying files completed we isolated the problem dvd rom is fine and the vista installer is fine as well.
If the problem only started in or during attempting to format you HDD might causes the problem.
Nov 10, 2009 | Dell Computers & Internet
I cant boot from the CD/DVD drive.
Watch on the bottom of the screen when the PC is re-booting for a "Boot from CD" message, it may go by quickly, and hit any key to boot from the CD.
Unleash Your Computers True Potential!
Apr 19, 2008 | Compaq Presario R3000 Notebook
CD/DVD hardware not found on "my computer"
PLEASE TRY TO BOOT UR LAPTOP WITH A BOOTABLE CD AND IF IT BOOTS THEN U HAVE A PROBLEM WITH THE OPERATING SYSTEM AND U NEED TO FORMAT UR LAPTOP.AND IF IT DOSENT BOOT THEN UR CD OR DVD ROM IS FAULTY AND U NEED TO CHANGE IT.
Feb 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Bootmgr error
theres several stages involving formating a disk.
this error however, appears to be discribing a boot-manager program.
Try booting with Windows in the actually DVD Drive.
If this does,nt work, re-format the hard-drive. or obtain a setup disk from your computers manufacturer.
i.e Compaq.
Mike @ Compurepair.
Feb 24, 2008 | Compaq Presario 2700 Series (222123-001)...
Computers & Internet Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
