IMic doesn't work with Logic Pro 9
I had a similar problem, but I managed to solve it; however, I'm using different recording software. The iMic simply does not have built-in input monitoring. Chances are, you are getting an input-signal but it is not being monitored. Try to find some kind of input-monitoring in your recording software. I found a toolbar, in my recording software, called "playback state" that has an option for input-monitoring. Search the help file index, within your software, to find something similar. Here's a quote from iMic's quickstart guide that might be of further assistance:
"In order to hear your turntable or microphone, you will need to enable an important preference in your recording software, usually called “Playthrough.” It may also be called Monitor, Passthrough, Cue, Preview, etc. Enabling such a feature tells the software how to route your audio, and is necessary for monitoring even when not recording."
Moreover, once you've solved this, I recommend using the iMic for both input and output, as latency with onboard-sound-output will likely be intolerable for input monitoring.
