Question about Toshiba 32WLT66 32 in. LCD HDTV
I have toshiba 32wl66es from aperiod i get hd reciver called lyngbox but i have problem ..evry time i turn recievr on it can't feel that tv connected to it by hdmi and feel that it scart i don't know wht is the problem so can u help me to solve it
  • 4102 Answers
SOURCE: hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Posted on Jan 16, 2008
ARTGIRTNY575
  • 96 Answers
SOURCE: toshiba 42HP66, HDMI problems
Your Cable box might need to be reprogrammed. Call the cable company and they will drive you thru the steps to program it, this way you will get the channels. This process might take you 30-45 minutes.
Artgirlny
Posted on Jul 12, 2008
tray06606
  • 59 Answers
SOURCE: Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Posted on Jan 10, 2009
  • 46 Answers
SOURCE: No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Posted on Jan 16, 2009
  • 135 Answers
SOURCE: will using a gold hdmi lead as opposed to scart improve picture
only on the hd channels
Posted on Apr 13, 2010
No Video Signal - Black screen with Blue Bar that reads "No Video Signal". Eversince we got a new HD reciver to view our new Toshiba 40" tv in HD, we have been having this issue! Lately it...
One of the things an HDMI connection does is allow the TV and equipment to talk back and forth to each other. When you turn the TV off it ends this connection but when you turn it back on, it doesn't communicate correctly. The analog inputs don't do this that's why when you change inputs and go back to HDMI it works, because the TV reestablishes that connection. You didn't list the model of the TV but go to "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp" and click download. Enter the TV you have and click "GO". A list of downloads comes up and your TV may have a firmware update for it. There is instructions on how to do it. Even if this doesn't fix this problem, it is still good to do to avoid other problems. Another solution is to use component (Red/Blue/Green) cables. The highest resolution they support is 1080i, HDMI is 1080p. Depending on the model of your TV and what your watching though, you might not see a difference. TV2 will never have this problem because it is not connected through HDMI.
Apr 19, 2011 | Televison & Video
I don't now how i recive tv chanels in hd
Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
Mar 13, 2011 | LG 32LG30 32 in. LCD HDTV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
How do i get high definition picture ?
Yes, you need a HD Receiver. You can buy your own or rent it from Direct TV
Nov 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
May 04, 2009 | Toshiba Televison & Video
No picture when first powered on; aperiodically needs reboot
Can you switch to another input such as DVD to see if the loss of audio is occurring there as well? This would let you know if the problem is only happening with the Comcast receiver or if it happens with other inputs as well.
Mar 16, 2009 | Toshiba 42AV500U 42 in. LCD HDTV
Picture quality
The output from your sat reciver is not HD unless it says right on it that it is . The signal your getting now is a digital signal from the dish to the reciver, but from the reciver to the TV set, it is analog. To answer short and sweet, Yes, you will need an HD reciver for the satallite to get the most out of your HD TV set. Good Luck Ps and please dont forget to rate this.
Oct 16, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Open Questions:
See all Toshiba 32WLT66 32 in. LCD HDTV Questions
Toshiba 32WLT66 32 in. LCD HDTV Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
