Turned the switch dial nothing comes on for my air or heat
Have you checked the breakers?
Posted on Mar 18, 2011
I have a superworks air compressor model 2hdd.....i have plugged it in...connected the hose...pulled the on/off button but don't get any air coming out of the hose..there isn't any kinks....is there...
there is a red knob above the dials? that i remember.
turn it down for more air pressure. If it's all the way up you'll get nothing.
Jan 19, 2018 | Garden
Furnace turnoff just before the blower go on.
You are to be commended for noticing this sequencing of events-- Good observation!
You need to adjust the Plenum control switch. (Or fan control switch)
Usually at the top front of the furnace, is a Fan control switch--
It is called the Plenum switch-- and it senses the temperature of the Air being heated by the fuel--
(Is your furnace Oil or gas?-- if Gas-- is it LP or Natural?)
This switch Has a cover that can be removed-- inside is a round dial, with some adjusting screw, and Degrees stamped on the perimeter of this round dial.
You can take the cover off, while the furnace is running-- (Just do not touch the screw terminals that have electric power to them--
You can rotate this dial, and it will turn the fan on-- (Or if the trip levers are mis-adjusted-- it might shut off the burner-- just rotate back the other way, and it will re-light etc.--
The purpose of this control is to make sure your fan is not blowing COLD air.
So-- lower the 'ON' switch tripper, down lower, so the fan will turn on sooner.
You may have to loosen a set-screw-- but usually they are just friction held-- and can be forced to slide (rotating CCW) to the lower temperature setting.
(If you get it too low, it will be blowing cooler air than you like at the registers.)
However-- to get the most heat from your furnace energy source-- you want the fan to come on as early as you can tolerate-- That will be delivering HEAT to your occupied space sooner, and giving yo more of those dollars you are spending on fuel, in the orm of heat in your house!
Tell us more
Mack B
Dec 28, 2010 | Heating & Cooling
I dont no how to work them,ive switched it on at the wall and put both the input and output dials onto max.do they ususally take over a day to gather heat as mine had no heat in it at all lastnight.theres...
what kind of air con are we talking about. a box air con in your window ? whens the last time you have seen it heating? does it cool. it should take 1 min for the fan to start 90seconds for heat/cool air to come out
Nov 09, 2010 | Heating & Cooling
Amana LG4409L Gas Dryer: Ignotor comes on when
The igniter or gas valve could be defective.
Nov 18, 2017 | Amana Dryers
Heater temp on mercury '98 mountaineer only blows hot
Everything that is heat and cooling in a vehicle is controlled by vacuum from the engine. It appears to me that your blend door vacuum line to the temp control switch is either off or cracked/broken and not making things work the way you want/expect. It's the vacuum friend.
Jul 01, 2017 | 1998 Mercury Mountaineer
The problem is with the heater.
3 words come to Mind. Heater Blend Door
Mar 17, 2009 | 1999 Ford F150 Regular Cab
My fan limit switch will not shut the fan off in heating (gas). The dial on the limit switch rotates till the shut off point then sticks. I have to turn it manually to shut it off.
Make sure nothing is bent and causing added pressure to keep it sticking.
You will likely need to replace the limit switch.
I don't know your model, but its probably 2 wires, 2 or 4 screws and runs about 20 to 40 bucks for the part.
Turn the power off first.
Dec 06, 2008 | Heating & Cooling
NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Nov 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
GE zoneline - about 23 years old
theres a heat relay and also the wire used for heat.either could be bad.
Nov 05, 2008 | GE Zoneline AZ38H12DAD Split System Air...
No Heat!
Sometimes too much dust around the heating elements can cause the heater to switch off to prevent a fire. Check for dust build up first. You can try using a can of compressed air that can be found at many electronic stores.
Oct 26, 2007 | Vornado EH1-0014-01 Compact Heater
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
