Question about Nintendo DS Lite Console
Nintendo DS Lite
How do you reset to factory setting?
  • 1 more comment
  • julio_mada Aug 04, 2008
    DS would not charge.. i place the power cord connection into the DS and the orange light turns on for a few seconds and then shuts off.... i cant tell what is wrong with it.. i need help to see if it is internal??
  • Anonymous Aug 05, 2008
    I have the same problem as Julio, when connected to the charger the light comes on for a second only. The DS does not turn on at all, also when connected to the charger. I have changed the charger and the battery but no luck. Any ideas?
  • jasg Aug 22, 2008
    mine does the same thing. I had a problem in the card slot which I fixed (bent pins) but I hadn't used the DS for about 6 months, so i suspect the battery died. I replaced the battery but the light goes out after about 1-2 seconds. I checked the old battery in another DS and it was ok. The strange thing is, if you put the charger on the DS without the battery installed, the light does the same thing. now I suspect that the insides are fried... any help would be greatly appreciated.
Either replace the battery, or let nintendo do it. There is no button to reset to factory settings, sadly.
Posted on Mar 27, 2009
    Problem Solver:
  • 5 Answers
Take the battery out of the DS for a couple of minutes, this will reset to default settings.
Posted on Aug 05, 2008
SOURCE: delete files on Nintendo DS Lite
You can simply remove the Li-ion battery for a short while - it doesn't retain info when batteries removed.
Posted on Sep 19, 2007
  • 12 Answers
SOURCE: nintendo ds lite won't charge
Sounds like your battery is toast, buy a new one from nintendo, or ebay.
Posted on Aug 15, 2009
  • 218 Answers
SOURCE: Nintendo DS lite "L" "R" button dont work
OK the buttons are probably dirty. I had this same problem with my DS. Pry open the outside edges of the buttons until there is a gap. Blow into the gap while making sure you dont spit in the console. This should clear out the dirt and make your buttons work.
Posted on Dec 26, 2009
open it up and clean out the ds
Posted on Apr 12, 2008
  • 85 Answers
SOURCE: Is my Nintendo DS Dead?
You are going to have to send it so that they can reset your system. Also, it could be that it is working but there is a short to your LCD screen. look around at some companies that fix gameing equipment. I went to and they fixed my sons DS. he had dropped it and the top screen would not come out. they had to change out the LCD screen.
Posted on Apr 24, 2007
I haven't played my D.S. lite for about a year, so the battery life died, but when i put it on the charger and tried to turn it on it did not turn on. it shows the light that it is receiving power, what...
Try performing a factory reset.
Reset Factory Settings for Nintendo DS
1. Take the Battery out and wait 45 seconds or longer and then reinstall the battery.
a. Turn the DS over and remove the small screws holding the battery access cover
b. Remove the battery
Feb 27, 2011 | Video Game Consoles & Games
How do I reset "Littlest
Unfortunately there is no easy solution for this problem. The only way I know of to factory reset a game for Nintendo DS is to use a third party application with a backup card (acekard, R4, etc). There is a program for use with those cards that will allow you to do it, but the legality of that option is sketchy at best. Sorry I couldn't be more help.
Feb 26, 2011 | Nintendo DS Lite Console
How to reset your nintendo DS
Hi. Here's the procedure on how to reset the console. Take note that if you are going to do this procedure this will erase all of the data saved on the system and restore the unit to its original factory settings.
Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit, and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
  • 2 Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
  • 3 Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not reset the unit.
  • 4 Put the battery pack back into the unit. Just line it up in the compartment and push it back into place.
  • 5 Replace the cover. Secure the cover back into place with the screw.
  • 6 Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all-new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
  • Sep 12, 2010 | Nintendo DS Console
    Re set ds game
    This will reset the device to its factory settings
    Let me know if this helps
    Dec 01, 2009 | Nintendo DS Lite Console
    Why is my ds lite keep resetting itself to factory settings?
    maybe thereis something wrong with the machine.pls send it to ur after-saling center to let it run normal.
    Aug 10, 2009 | Nintendo Action Replay DS for DS and NDS...
    DS lite only playing one type of game
    Reset Factory Settings for Nintendo DS 1. Use a small screwdriver to unscrew the back cover.
    2. Remove the battery.
    3. Wait a few seconds.
    4. Replace battery.
    5. Turn on DS.
    6a. If you have to re-enter your nick-name/time and date etc, it has worked! Go to 7.
    6b. If not, remove the battery again and wait longer.
    7. Replace cover and screw back in place.
    Jul 31, 2009 | Nintendo DS Lite Console
    Where is the reset butten on the nintendo ds lite?
    Turn off the DS
    Remove the game
    Turn on the DS
    Go into Settings
    Go into Options
    Go into Start-up
    Switch from Auto Mode (game will begin automatically) to Manual Mode
    Mar 26, 2009 | Nintendo DS Lite
    I want to factory reset how
    Is there a possibility to reset de DS lite?
    When i put on the power nothing happenes, even when it is connected to AC/DC adapter/
    Mar 02, 2008 | Nintendo DS Lite Console
    Nintendo ds lite time and date freezing
    Call a nintendo help line or exchange it where you purchased the ds and get a new 1 for free.
    Dec 28, 2007 | Nintendo DS Lite Console
    Nintendo DS Lite Console Logo
    461 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
