Question about Weiser Lock POWERBOLT ELEC DEADBOLT
The lock has reversed itself. I just replaced the batteries and now the door unlocks pressing the lock button and only locks when I put in the code.
  • 963 Answers
Did you accidentally remove the jumper that determines the "handedness" of the lock?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Mar 19, 2011
My BMW Z3 I took the battery out now my doors will not lock or unlock but if I try to unlock door car will not start but if I disconnect the bat and put back and don't try doors it will start I need...
Put your key in the ignition switch it on and back off remove key no PRESS AND HOLD UNLOCK BUTTON without releasing the unlock button press the LOCK button 3 times within 10 seconds doors should lock and unlock rapidly to confirm it worked you must do this sitting in the car with doors and windows locked
Apr 07, 2014 | Cars & Trucks
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Keyless remote
hi Alan
what procedure you are doing for remote matching?
try this one and let me know.
1 Unlock the car, get in and close the door
2 Switch ignition on
3 Press the door lock button on the dash to lock the car
4 Press and hold the door lock button on the dash, the alarm will beep
5 Keep holding the door lock button on the dash, press and hold the lock on the remote,
the alarm will beep
Repeat (5) for the other remotes,
6 leave the door lock button on the dash, the alarm will beep, switch ignition off
Feb 13, 2014 | Suzuki Cars & Trucks
Sorry my car was not listed so picked Altima 2003 Micra Intelligent key fob not working properly. Can drive the car but cannot open or lock the doors. Did get fob wet. Now dried out. Worked for first few...
You are going to need to check the power lock control moduel on the inside of the door panel. If the FOB appears to be working but the doors are not unlocking, you need to check this. I would also replace all fuses that control the locks. If both of these devices check out ok, you may need to replace your FOB. To check your power lock control moduel, manually lock and unlock your doors by pressing the lock button on the inside of the door. If it does not work, it is either the fuses or the power lock control moduel. If it works, your FOB has gone bad. Hope this helps! Please rate 4 thumbs up!
Apr 18, 2011 | Nissan Altima Cars & Trucks
Wrwent to unlock my 1996 Hona accord with the remote and noticed the light was on. It wouldn't unlock the door . Put in a new battery and that didn't work. Do I need to reset the alarm? If so, how do I do...
Remote Transmitter Replacement (Wagon)
Use the following procedure when replacing one or both remote transmitters:
  1. Open the driver's door.
  2. Press and hold the driver's master door lock switch down in the UNLOCK position.
  3. Quickly insert and remove the key from the ignition switch five times, then insert the key the sixth time, and leave it in the ignition switch. (This routine must be done within 1O seconds.) All the doors will lock and unlock to indicate that the control unit is in the program mode.
  4. Press either button on the replacement transmitter. All the doors except the driver's door will lock and unlock to indicate that the control unit has accepted the transmitter into its memory. If either transmitter button is pressed again, all the doors will lock and unlock.
  5. To program a second transmitter, press either button on that transmitter. The doors should lock and unlock as described in step 4.
  6. Release the driver's master door lock switch.
  7. To exit the program mode, close the driver's door or remove the key from the ignition switch.
Dec 18, 2010 | Honda Accord Cars & Trucks
My key remote to lock the doors suddenly stopped
hi yes this can be done, here is how
make sure you have all keys ready to reprogram close all windows and doors insert key into drivers door lock within 5 seconds of putting key in door lock turn key to unlock position 3 times this puts the key into programming mode ( door led should be on ) press and hold lock button, within 5 seconds of holding lock button press unlock button 3 times ( keeping lock button pressed at same time) then release lock button that should be it...to make sure correct programming is achieved key led flashes 5 times, and door led flashes 6 time, if you have more than one key do same as above within 15 seconds of doing the first key..
phew..lol, well i hope that will work for you..please vote thanks
May 14, 2010 | 2007 Ford GT
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Jan 22, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
95 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
