Question about Toshiba 50HX70 50" Rear Projection Television
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal part of some of the crosshairs is at an angle instead of being horizontal. Do I just need one ic (stk392-110) for the blue lamp? Or could it be something else? Where is the ic for the blue lamp located?
  • Toshiba Master
  • 8,457 Answers
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Posted on Mar 18, 2011
It looks like the bulbs are not aligned. The upper half of the picture is fine. The lower half has the red above the blue to there is double picture. I just picked up the TV for free. Any suggestions?
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have 2 dead STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 13, 2010 | Toshiba 55HX70 55" Rear Projection...
Red and blue overlap shadowing
Sounds like a convergence ic problem, normaly i tell people to replace the ic's but in your case try to re-solder the pins on the ic first, you may just have some pins broken loose from the board. Locate the stk392 ic's there will be two of them located on a heat sink, unplug the tv and get to the bottom side of the board and re-solder the pins. if this does not work, then replace the ic's
Sep 02, 2009 | Mitsubishi WS-65807 65" Rear Projection...
MY TV NOW SHOW BLUE AND YELLOW AT THE TOP AND
i have a 52 in rca tv and i turned it on and now there is a blue and yellow stripe at the top and bottom of the tv. and the people have a blue shaddow around them ? how can i fix this?????
Aug 25, 2009 | Hitachi Televison & Video
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
50hx70 blue projection light is concaced at top and bottom of tv
When the convergence amplifier ICs go bad (STK392-xxx), they RARELY cause more than one color to go out. The fact that the top and bottom of the picture are effected indicates the vertical convergence IC. Replace both, and while you're in there check the bias resistors... it is likely one of these is open. Once the ICs have been replaced (as well as any open resistors), customer convergence followed up with the auto convergence should do the trick.
Nov 19, 2008 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 Convergence reset
press mute button once after press and keep pressing mute again and press de menu button on tv .when tou see S on screen press 7 you are in convergence adjusting mode
Aug 03, 2008 | Televison & Video
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Toshiba 56H80 Convergence Problem?
There are 2 large IC's in your set and one of them has burned out. These are called convergence output IC's and are usually the STK392-010's. A good idea would be to go ahead and replace both with the newer, upgraded STK392-150 IC's. A good tech can change those IC's in about an hour and a half, and when I do a housecall for a set like that I charge $150, but shops in your area will vary so be sure to ask around.
Sep 07, 2007 | Toshiba 56H80 56" Rear Projection...
Toshiba 50HX70 50" Rear Projection Television Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
