Question about Health & Beauty
When i put strip in freestyle freedom blood meter instantly shows er4 and i have no manual, this is not a lite
Replace the battery
Posted on Jul 13, 2011
Accu Check Active showing Trouble E-1
The electronic error code refers to either
  1. your glucose level may be extremely high or a meter or a test strip error has occurred.due to insufficient blood sample on the test strip.
  2. A used test strip was removed and reinserted.
  3. The test strip may be damaged or not properly inserted
Try turning the meter off and on or take the battery out for a few seconds and try testing glucose levels again. In any event, check your meter's manual; if unavailable- you can download an electronic version of the manual from the manufacturer's web site; or some meters you can browse the info from your meter's screen menu.
Other options, replace the battery with a new one or perhaps your meter has met its end-of-life usage.
Be well!
Feb 12, 2017 | Active Health & Beauty
REASONS FOR FLASHING BLOOD DROP SYMPBOL ON CHOLESTEROL METER WHILST STRIP WAS COVERED CORRECTLY WITH BLOOD
I use an Abbott Precision Xtra glucose / ketone tester, that sound similar to yours. On mine, you do not place a drop of blood ON the strip, you place the end of the strip in the drop of blood. There is a very narrow channel that then sucks up the blood by capillary action, and in the case of my tester, it beeps to acknowledge when it has enough.
On the colored side of my strips you can see the blood rise in the opening. After the beep the symbols change to a countdown while the meter does its work
I hope this will gice you at least one thing to try and observe the results of.
It is possible you had a bad strip. It does not happen often, but it does occur from time to time.
Good luck
John
Sep 17, 2016 | Health & Beauty
The meter says E 5 on it what does this mean ?
Cant remember exactly but i think that is probable blood incorrectly put onto test strip, probably before meter is ready. You have to wait for the little drop of blood to appear on the display.
Mar 15, 2015 | Accu Check Aviva Plus Blood Glucose...
How do I set time on unit
To set the time do the following:
Turn meter on without test strip.
Press the time for 3 seconds.
Select 12 or 24 hour clock use up and down arrows to change, then press the butterfly.
The hour should now be flashing, press up / down arrow to set hour, then press the butterfly.
The minutes should now flash, use up and down to set minutes then press the butterfly.
The month now flashes, use up and down to set, followed by butterfly.
The day is next, again use up / down to set then press the butterfly.
Finally the year can be set by using up / down, after pressing the butterfly this time the time and date will be set, you may turn off the meter.
Sep 10, 2014 | Abbott Diabetes Care Freestyle Freedom...
Optium xceed user manual
Blood put on to test strip too soon, you need to wait a short while after fitting strip before putting blood on for testing. Not sure of exact time but the machines display should change. Hope this helps
Jun 23, 2014 | Health & Beauty
E-5 error code
  • Blood was applied to the test strip too soon. Slide and release buttonicon.gif to turn off the meter and release the test strip, then turn on the meter again. Repeat the test, waiting for the flashing test strip and blood drop symbol before touching blood or control solution to the end of the test strip.
  • The test strip was bent before the test started. Repeat the test with a new test strip.
  • There is moisture in the meter. Slide and release buttonicon.gifto turn off the meter. Let the meter dry at room temperature.
Apr 03, 2014 | Accu Chek Compact Plus Blood Glucose Meter
WHEN I TRY TO CHECK MY BLOOD SUGAR, IT EITHER SAYS ERROR 2 OR ERROR 5
Error
1 too hot or cold
2 sample not detected or using wrong strip
3 used strip, stip out too long or blood on top of strip
4 meter error call for help
5 very high blood glucose (600+)
6 strip removed during test
8 memory error, result not recorded
9 communication error.. call for help
hope this helps, please note that online manual is available if you search for it online, and this is why it is immportant to keep all instructions in a safe place.
Jan 13, 2014 | Walgreens Trueresult Blood Glucose Meter,...
Freestyle freedom meter reads error 4 what does it mean
goto the following to get online manual: abbottdiabetescare.co.uk
Jan 25, 2013 | Abbott Diabetes Care Freestyle Freedom...
Health & Beauty Logo
963 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
