Question about SanDisk Clip+ MP3 Player
I have a sansa 8mg clip and usb cable attached to my computer but it will not read it to put songs on it or charge it.... but it works fine on my laptop. what can I do to fix this?
  • 29 Answers
Have you try on another port? If yes, you may try to uninstall your device from Device Manager (Right click on My Computer Icon, find the hardware tab and select device manager).
Follow this step: 1. Attach your device to PC and go to the Device Manager. 2. Find ALL icon with the yellow exclamation mark, right click on it and choose to uninstall. 3. Select YES on ANY warning box. 4. Restart your PC. 5. Now you can attach your device again. 6. You may asked to install driver for your device. Just click yes/next and continue the installation.
Posted on Mar 18, 2011
My sansadisk clip works, but when I plug the USB cable into the computer it switches itself off. If I plug the USB cable into the sansa without attaching it to the computer its fine, its only when I plug...
I think your USB cable is faulty. Try to connect your player using another cable. If this can not solve the problem your device must have some hardware problem and to fix it you should carry it to service center.
Bye, gylacz
Mar 22, 2011 | SanDisk Sansa Clip MP3 Player
Hello, I Think what you to do is detach it from other power source and try pluging to the computer first and see the resault it gives to you. I hope it works for you. Please vote me.
Mar 22, 2011 | Computers & Internet
I have a clip on 8mg sansa ipod. Now I have a new computer pc with windows 7 OS. I am having problems with getting old song off and syn new songs. I have downloaded the the new bit for the drivers, still...
Copy this link into a new window and see if this helps this guy helped me. > http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <Hope this is your solution.
Jan 02, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip sandisk 2gb won't charge. Thought it was low and after plugging it in to computer overnight it wasn't fully charged but worked the next morning but suddenly died. Now it won't charge. Sansa...
I had the same problem this morning, albeit with my 8G Clip. Nothing worked -- the thing seemed dead as roadkill -- until I found a link about "forcing MSC mode." Basically, it told me to hold down the center button while plugging my Clip into my computer using my USB cable. Suddenly, boom! It's awake and alive and happy again. I'm unsure how that works, but that did it for me.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Old songs dont show
If you mean that the songs don't show up on the computer screen, then you probably need to change the USB MODE setting on the Clip. To do this, disconnect the Clip from the computer, then scroll to SETTINGS. Select Settings, then scroll to USB Mode and select it.. (If your Clip is very old it might not have a USB Mode listed under SETTINGS. If this is the case you should update your Clip's Firmware from the sansa website). Older computers recognize the MSC Mode while newer ones should recognize either mode. (except XP Professional doesn't seem to recognize the MTP mode). Songs entered in one mode won't show up on the computer if you're in the other mode. If you mean that the songs aren't showing up on the Clip's own screen then this solution probably won't help. By the way, I've never had any luck with the "auto detect" mode.
Jun 03, 2009 | SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2GB to my computer it doesnt show in My Computer section so that i can down load music into it
just figured mine out. turn your clip off. put the slider in the hold or lock position. press and hold the center button on your clip. continue to hold while attaching the usb to your clip. keep holding the center button as clip powers up. after appox. 12-15 seconds, your computer should read the clip. i am running windows xp and this is the ONLY way my comp. will read the clip. but it works great!! good luck!
Apr 23, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player wont charge
Try to charge it on another computer to determine if it's your computer. If the other computer works, then the problem is with your computer. (If your computer has multiple USB ports, you could also try another one.)
If the other computer does not work, then the problem is likey your cable. If you have another friend with the same device, borrow their cable and try it. If it works, then you need a new cable. If it doesn't work, then your Clip has issues. You could try doing a complete reset on it by sliding the power button up and holding it for 15 seconds (as described in the manual at http://www.sansa.com/sites/default/files/downloads/CLIP_UM_0608_ENG.pdf).
Jan 05, 2009 | SanDisk Sansa Clip MP3 Player
Computer doesn't recognize MP3 player -
Make sure you are using a data transfer cable, and not just a "Charge Only Cable"... There is a difference, and they may look similar and both connect via USB so it can be tricky.
Apr 06, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Clip+ MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
