Question about Sony Audio Players & Recorders
I'm trying to record an original cd to mini disc and it just keeps flashing up c14 error.. why is that?
    Scholar:
    New Friend:
  • 134 Answers
Try recording it via analog, the manual says you may be precvented from making a digital copy of some commercially available CDs.
Posted on Jun 09, 2013
3 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: when i inserted my mini disc it said TOC Reading
Sounds like you lost power when you were finishing recording a disc. On a home unit it got unplugged before you had the TOC written, or on a battery unit the battery died when it was writing the TOC (table of contents) for the disk.
Posted on Jan 16, 2010
  • 189 Answers
SOURCE: Giving
HELLO
Strange one this! C13 is a protection error, but the machine should play discs that it recorded. It could be that you may have to give the laser lens a good cleaning by using a cotton bud and a little isopropyl alcohol. You will have to remove the cover to do this and when you clean the lens use a gentle circular motion.
Don't soak the cotton bud when you do this but if you do, remove any excess liquid. Leave it for about 5-10 minutes then try the machine again.
If there is no change, then you will have to take it to a service centre in your area.
GOOD LUCK!
Posted on Apr 25, 2010
After recording, I recieve a toc error c14 when I try to finalize it. How can I fix this problem?
There's a solution to the problem : the problem is one word..; '''Sony''. Throw the unit away as to my knowledge there is no company who makes discs that will allow a TOC (table of contents) to be written to the disc. All those Sony units were only designed to be accept Maxell CD-R Music Pro blank discs. They are unfortunately unavailable /no longer being produced. Step one: .Buy a Tascam recorder they accept consumer grade cds.. Step two: Boycott Sony as most of us who owned one of their standalone units didn't get two years of use out of it..including myself and most i've ever talked to about it.
Feb 18, 2015 | Sony RCD-W500C 5-Disc CD Recorder
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
C14 error on sony w500c/w100 when finalizing disc! what can i do
could be an erro0 on the disk data try 2 clean the cd player
Mar 11, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
To whoever can help...I have a Sony, RCD W10. I am receiving 2 error codes when I proceed to record a cd. Error code C13 and C14. Does anyone know what this might mean? Simply frustrated
They are what you call fault codes. A fault code provides a machine-readable identifier that can be used to programmatically identify the error condition and respond as appropriate
Jan 16, 2011 | Audio Players & Recorders
When i inserted my mini disc it said TOC Reading then said Toc Error and C14. What is the problem?
Jan 01, 2010 | Audio Players & Recorders
Cd wont play after finalize an toc error C14 appears
You can visit this link to check it this error out.
toc error C14
Best regards.
May 26, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Intermitant problem after recording.
ok first thing do not put a cd lense cleaner in the machine this will ruin the optical lense imagine being slapped round the face with a yard broom same thig very abrasive .what type of discs are you using /and how old are the discs and the player/recorder code C13 Mean cant see t.o.c lead in / C14 means laser voltage is low . if the iscs that you are using are dark in colour old type the dye has gone bad if new recently purchased and a good brand like tdk or maxell they do the same the optical assembly is shot . regards kirk
Dec 09, 2008 | Onkyo TX-SR303 Receiver
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
