Question about Dishwashers
I have a Bosch SMU4056US/09 dishwasher that does not fill. Using a meter, I have confirmed that the inlet valve solenoid is receiving power at the appropriate point in the cycle. I have confirmed that the overflow float switch is not open. I have removed the inlet valve and connected it to a garden hose and observed that water flows when I energize the solenoid but that it flows quite slowly with little pressure. I have observed that water flows into the washer but also slowly. The inlet valve on this model has what looks like a pressure regulator after the actual valve itself although it is all part of the inlet assembly. Am I correct in assuming that the inlet valve is partially failed such that it does not open fully or that the pressure regulator part is not allowing adequate flow and in either case I should just get a new valve assembly? The dishwasher is 16 years old.
  • 11 Answers
SOURCE: Bosch SHU4300 Water Fill Issue.
Similar problem for us turned out to be water accumulating in the tray which set off the float switch.  I vacuumed the water out and function returned to normal.  However, we are now facing a repairman's assertion the clay in our well clogged the water inlet systems necessitating $285 in repair parts and labor.
Posted on Oct 13, 2007
  • 489 Answers
SOURCE: LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Posted on Jul 23, 2008
  • 71 Answers
SOURCE: no water enters dishwasher (Kitchen Aid KUDS25SHBL1)
usually 120 volts
Posted on Dec 12, 2008
  • 221 Answers
SOURCE: Dishwasher top spray bar does not spray due to low water fill
Check the water hose going from the sink to the dishwasher to make sure it is'nt clogged, if there's a water shut off valve under the sink make sure it's fully open, also check to make sure the spray arms at the bottom of the dishwasher that supply water to the top rack is clean with no debris or obstructions in the spray hole's, the water entering the dishwasher should be at a warm temp, if it's cold the dishes will not get clean, you should have good water pressure from the house supply for it to fill properly, the float is also called a flood switch, it should not be activated during the water fill cycle, if it's activated it will shut off the water inlet valve and the wash cycle will stop or the dishwasher will drain, if your still having wash problems it could be a defective water inlet valve or a bad timer, if that's the case you might have to call an appliance repair man, hope this helps, good luck.
Posted on Mar 28, 2009
lsteward68
  • 331 Answers
SOURCE: no water being allowed into dishwasher
you may have a bad water soleniod. there is also a mesh on the solenoid. go here to identify
if you have your model number and make you can go here to identify it www.techray1.com then click on the guru guy on the left. this will open another window. on the left you can select your model and unit and part. If this helps please rank me
Posted on Jun 22, 2009
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
What should the electrical resistance of the water inlet valve on my tester
Hello Tony;
My name is Peter. I am a retired field service refrigeration technician.
At the two terminals at the solenoid valve (no power) you should have your meter set at the lowest Ohms. The reading should be '0' if the solenoid is good. Any other reading it is bad.
Dec 14, 2014 | Bosch Dishwashers
Can i remove the aqua solinoid cut off valve from bosch dishwasher
the valve and wiring can be replaced you cannot remove it altogether as it wont be able to fill up, bosch aqua stops are normally powered solenoids that also double as the water inlet valve unlike most other aqua stops
Sep 27, 2014 | Bosch Dishwashers
Dishwasher will not fill with water when turned on
Hi and welcome to FixYa, I am Kelly
The following steps require using electrical power. You assume all responsibility / risk for any mis-fortunes cause by working on this dishwasher with power applied.
The first step will require using a meter on the water valve solenoid teminals.
- Remove all power.
- Remove the lower toe / kick panel(s).
- Locate the main water supply line and follow that to the inlet water valve.
- Slide the connector(s) off of the solenoid and read resistance on meter scale R x 1 or R x 10. You should read a low resistance. If you do not read any resistance the inlet water valve has failed.
If you do read resistance you must check switch the meter to AC voltage and apply power and read for AC voltage on the teminals of the wire harness.
- Start a reular wash cycle to where the unit should be filing with water.
it SHOULD read 120 VAC.
If you have no power at the connector teminals
- Check the float switch plastic FLOAT. If the float is stuck in the UP position due to food particulate on the FLOAT stem you willnot have power to the inlet water valve solenoid.
If you have power to inlet water valve solenoid and it is buzzing / humming but you get no water there is debris in the main water supply line. You wil have to shut off the water supply and clean out the inlet of the water valve.
The inlet water valve replaement part is here:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=233229
Detailed View
http://www.appliancepartspros.com/Appliance-Parts/bosch-water-inlet-valve-assembly-item-number-ap3783031.aspx
This is what the float looks like:
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-item-number-ap2802399.aspx
This is the level switch assembly:
http://www.appliancepartspros.com/Appliance-Parts/bosch-level-switch-assembly-item-number-ap2802390.aspx
This is the actual Float switch: (3 terminal)
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-switch--3-terminal--item-number-ap2802373.aspx POWER to the inlet water valve solenoid comes from this switch.
Check for s stuck float... and that the level switch is actuated as the float id lifed gently up and down. If you do not hear a micro-switch click the switch is bad. If the float is hard to move... clean it as best you can so that it moves freely up and down.
One of the above is causing your problem.
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | Bosch SHU9915UC Dishwasher
Bosch smu4096ud /14 dishwasher wont fill with water
Find out where the water is being stopped. Firstly at the wall. Then maybe at the solenoid (depending on the model) and then just trace the water line until you find out where it's being stopped.
Also I would recommend you run some nickel safe ice machine cleaner through the system to get rid of the 'white junk'.
Mar 11, 2010 | Dishwashers
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
My Bosch excell switches on, but does not fill with water. The impeller is working and there are no blockages. Any ideas?
Hi.
The following parts must be tested:
Check the inlet hose at the back of the appliance. Ensure that is not kinked or blocked.
Check the water level device. There must be a float switch inside the Tub. Some model may also have a pressure switch. The water level switch is tested bypassing it or testing continuity with an Ohm meter.
Check the inlet valve . This is tested reading impedance on valve solenoid contacts. The solenoid must show continuity on the Ohm meter.
If you need to call a technician ring the number listed on the owners manual.
Regards.
Dec 17, 2009 | Bosch Dishwashers
Water does not drain in my kenmore ultra wash iii 16779
Hi!
Thanks for using FixYa. Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, or flip the appropriate breaker in the circuit breaker panel. Locate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel in either the right or left corner. There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate. On some dishwasher models, the door has to be opened in order to gain access to, and remove the kickplate’s screws. Close the door before you remove the kickplate panel.
You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water.
There will be two wires connected to the water inlet valve. If your dishwasher's water inlet valve has two solenoids, then there will be four wires. Label the wires so that you will be able to correctly reconnect them later. The wires are connected using slip-on connectors. Grasp the connectors and pull on them firmly in order to disconnect the wires from the valve's terminals. Do not pull on the wires themselves. You may want to use a pair of needle nosed pliers to help you.
Use your multi tester to test the valve for continuity. Set the device to the ohms setting x 1. Touch each of the meter's probes to a terminal. If you receive a reading of infinity, it means the valve's solenoid is faulty and the valve needs to be replaced. If your valve has two solenoids (four terminals), test the second pair of terminals in the same manner. If either pair of terminals receives a result of infinity, replace the water inlet valve.
You do not have to remove the water inlet valve from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Interestingly enough, it is entirely possible for your water inlet valve to pass the continuity test and still need replacing. This is because sometimes the valve itself is faulty, but its solenoids are not. For instance, a leaky valve may pass the continuity test, but because it is leaking, it should be replaced anyway. The same applies to valves that are filled with debris. The debris may be what is causing the valve to not function properly. If you are unable to clean out a debris-filled water inlet valve, you will have to replace it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Kenmore Dishwashers
Not take in water
Hi!
Thanks
Rylee
Nov 09, 2009 | Dishwashers
Washer does not fill with water
I checked the inlet solenoid valve to make sure it was receiving power, it was. I removed the left hand side panel of the machine. The labyrinth was blocked with crud as was the float switch assy,
Cleaned them out,with boiling hot water, it now works.
Jan 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
