i recently had to re-install windows ME on my pc..i now cannot install the camera...i installed the software from the cd..but when i plugged the cam into the pc..it went through found hardware process..then told me that the file kstvtune.ax was not found..& was unable to install...i have tried to install the driver from the intel site...but still the pc is telling me that it was unable to find the software for it...i have used the cam many times before so i know it works with this pc...but i have just hit a brick wall...please help...
Good
TEST
My pc camera has driver cd which is not compitable for advanced versions of Windos
Normal
0
Did you install the software with the camera connected to
the computer? Disconnect the camera from the USB port and reinstall the
software. When the program asks you to connect the camera, do so, and it
should work. Hope this is of some help.
Bud
Below is info for setting up Audio & Video to chat on
line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are
to be used with. Just installing the camera on your computer does not set
it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your
friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set
it up as follows:
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
I have
