Hello i have a 970 C45012 00 kenmore front load washer. would like to know tub size 3.1 or 3.5
yalmer
  • 552 Answers
SOURCE: kenmore front load washer Model 970-C40042-00
Click this link.
They will have a manual for you.
Posted on Apr 02, 2008
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
SOURCE: kenmore front load washer 970-c45072-00
We had the same problem and this website solved it for us. The child lock is on when the lock symbol light in the lower right of the panel is on. The machine will not start with the light on. If you press the Option and Select buttons together (there is a lock symbol with a line to the two buttons), the lock symbol light will switch between on and off. When it's off, the machine can start. None of this was in the "Use and Care Guide," maybe we lost our manual. But thanks for helping to solve the problem!
Posted on Jun 10, 2009
housejess
  • 317 Answers
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Posted on Nov 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Model 970-C41074-00. Front Load
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My kenmore 970-38712 washer makes a terriible banging noise on the final spin.
http://www.searspartsdirect.com/model-number/9703871220/0582/0153200.html?searchType=modelSearch&q=970-38712&searchTerm=970-38712
This link shows you your tub parts. There are 2 springs and 2 shock absorbers. Those may be bad broken or loose and one other thing to check is make sure the inside drum has not broken off of the spider assembly in the back. An easy way to check that is open the door and grab the front lip of the metal tub and try to move it up and down, you will notice a huge amount of movement if it is broken loose. The videos I posted apply to all front load washers, The first 2 are great on diagnosing and the last one shows whats left of a broken spider gear. Kenmore Washing Machine Model 970 3871220 9703871220 970 3871220 Parts
If it is the spider support assembly then you will have to replace the entire inner tub and that is about $400 just in parts.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 14, 2017 | Kenmore Washing Machines
Drum has detached Model 970 38712 10
Hi, it sounds like you have a major problem with your washer. The inner steel basket has a shaft attached to the back of it that goes through the rear of the outer plastic tub and attaches to the drive pulley. More than likely the shaft has broken off, the basket alone is over $500.00. It will more than likely need the rear of the tub as well for the seal and bearing. I have seen this many times. I would recommend buying a new washer unless you have some sort of extended warranty.
Apr 16, 2014 | Kenmore 44921 Front Load Washer
970-C98802-00
see the video and fix it. God bless you
Jul 18, 2013 | Kenmore HE2 Plus Front Load Washer
Hi I've a front loading model 970-C42074-00 that is ruining my cloths, leaving grease marks on everything. Could the cause of this be bad bearings in the drum? I have tried increasing water temperature,...
woo stop adding more detergant . you get a build up over time you should only be using about 2 tblps no mor half that if you have a softner . ok chexk the door seal behind the gasket at the tub is there a gray slime on the plastic tub could be brown
Jun 03, 2010 | Kenmore HE2 Plus Front Load Washer
How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
Apr 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
