Msi.dtss error - Office Equipment & Supplies
3 Suggested Answers
  • 1011 Answers
SOURCE: during installation i get a
Dowload the driver from above link
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-49283-1&lc=en&cc=us&dlc=en&product=3192753&os=2093&lang=en
Disconnect the printer first, start installing the dowloaded package, while installing it will ask you to connect the printer, then connect it.
It should install properly.
regards,
Posted on Aug 10, 2008
VOTIT
  • 2071 Answers
If you're trying to install a printer and it will not install, be sure to check the Device Manager in the Control Panel for any Unknown Devices. Your printer will be come an Unknown Device if you plug the cable in before installing the driver software. Remove the Unknown Device and then unplug the USB cable. Next, install the software that came with the printer, and when finished, plug the USB cable back in.
hope this may help;
How to Load or Reload"HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
Try this one:
This document pertains to HP and Compaq Desktop PCs with Windows 7, Vista, and XP. An error appears that contains a filename ending with MSI. (MSI refers to the Windows Installer.) This error can appear while Windows is starting up or when a particular software program is opened. This error might appear after using a Registry Cleaner or Registry Fix tool.
See the following error examples. Your error might be slightly different, but it has a filename that refers to or ends with MSI.
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package 'TrayApp.msi' in the box below.
'HPProductAssistant' the feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Figure 1: Example of an MSI error
c01378399.gifUsing Recovery Manager to Restore Software and Drivers in Windows 7 HP Recovery Manager (Windows Vista)
  • HP application recovery process (Windows XP)
  • If errors persist, you can clean up the MSI registry entries by using Microsoft's automated solution. For more information, see Fix problems with programs that can't be installed or uninstalled (in English).
    Preventing MSI errors To prevent these errors from occurring, make sure that registry cleaning and spyware removal utilities do not remove files and registry entries associated with your software. Instead, if you no longer use a particular software title and want to remove all references from the registry, remove the software by using the Add or Remove Programs tool in Control Panel. The software uninstaller will remove the associated entries from the registry.
    Some products available for free on the Internet suggest that the registry needs regular maintenance or cleaning. However, use extreme caution when installing and using a registry cleaner. Many registry cleaners generate other MSI errors because they do not recognize valid registry entries and delete them. This can cause more MSI errors and prevent other programs from working.
    If you do decide to install a registry cleaner, be sure to research the product thoroughly, and then download and install programs only from software publishers that you trust .
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="" >
    NOTE:One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
    Jul 12, 2014 | HP Pavilion Computers & Internet
    How to load or to reload "HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
    Jul 12, 2014 | HP Computers & Internet
    3tegert
    Please elaborate your problem providing us with more details of the problem.
    Thanks for using FixYa.
    Aug 07, 2011 | Computers & Internet
    I keep getting a message saying tray app installation incomplete please insert cd. problem is I don't know which program did not completely install and this message won't go away
    There are 3 step to repair trayapp.msi error
    If you got trayapp.msi error then there is a 94% chance that your computer has registry problems. To repair trayapp.msi error you need to follow the steps below:
    * Step 1 - Download a Perfect Optimizer,install this error repair tool.
    * Step 2 - Click the Repair All Button.It will scan you pc for Free.
    * Step 3 - Then click the Repair All Button again and your done! It is very easy to repair trayapp.msi error.
    Here are the url of Perfect Optimizer:http://www.fixerrorsafe.com/ttfix-trayap
    Nov 13, 2009 | HP Pavilion dv9000z Notebook
    MSI.dot4wrp01
    Fatal Error during Installation - MSI.dot4wrp01
    Try this link. I was able to resolve this with this solution.
    Mar 25, 2009 | HP Photosmart C4280 All-in-One InkJet...
    During installation i get a fatal error HPSSupply.cab is corrupt go to fatal error and MSI.DTSS
    regards,
    Aug 10, 2008 | HP Office Equipment & Supplies
    VS_SETUP.msi FILE INVALID
    vs_setup.msi file is invalid
    Feb 11, 2008 | MSI MS 9205 Server
    Msi megastick 1 error
    Hi, The MSI Mega Stick normally comes with a utility/installer CD. On running setup, there is a software which would allow you to download the firmware to the Stick. Reinstalling or updating the firmware should reactivate your MP3 player. If the CD is not available, you can try download the same from the MSI site, the file name is MS5511and2_3.00.13_M.zip. Instructions are also posted on the site > http://global.msi.com.tw/index.php?func=downloaddetail&type=firmware&maincat_no=124&prod_no=47 Hope this be of help/idea. Post back how things are or should you need further information. Good luck and kind regards.
    Sep 02, 2007 | MSI MEGA Stick I (128 MB) MP3 Player
    138 people viewed this question
    k24674
    jasbo
    jasbo
