Question about HP Office Equipment & Supplies
I refilled my black cartridge and it had a leak and got all over, can I open the thing up and clean it up or not? I can build a computer but I know nothing about printers
  • 604 Answers
What a nightmare, I feel for you. the first thing I would do is try to mop up any ink that hasn't dried yet. After that take the doors off the printer and see where the ink went. If the ink is just in one area nd didn't get into the components or moving parts you might be ok and just let it dry. Once its dry it won''t get ink on anything, so it might not be such a bid deal after all. refilling old cartridges is always a bad idea and never saves money in the long run. I've been there and done that.
Posted on Mar 18, 2011
HP black ink cartridge and HP deskjet pritner 1055
end of life.
buy a real laser jet like hp1102w.
or better
inkjets stink, imo
Mar 02, 2017 | HP No 60 Black Ink Cartridge
I replaced a new cartridge to my printer and now is not printing. Before I tried to refill the cartridge and it did not work, it was leaking black ink. Now with the new cartridge it does not work either....
Canon PIXMA MX860. Turn it off. Open it and check if the black ink leaked inside most especially on the cartridge panel. Clean there using surgical spirit or petrol using a cloth.
Fit the cartridges in their actual point (Black and Color). Connect its power and USB cables and then switch on. This should work for you.
Jun 15, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How do i refill the # 96 & 97 ink cartridges
Hello!
To refill your cartridges, you will need a syringe, a needle, ink of course, some toilet paper or tissue and gloves (recommended!).
Turn the printer on, open the cover and remove the cartridges from the printer.
1. BLACK CARTRIDGE:
  • Peel off the top label- you should see several holes.
  • Fill the syringe with 10-15ml. of black ink.
  • Slowly inject ink in any of the holes (the best way is to pour a bit in each hole, so the sponge inside can absorb more ink)
  • If any ink starts coming out from the refill holes, remove 1 or 2ml of ink.
  • Also, always check if there is ink leaking from the print head (The nozzle or print head is the porous metal piece at the bottom of the cartridge). If there is, simply remove some ink.
  • Gently wipe the electric contacts on your cartridge.
2. COLOR CARTRIDGE:
  • Peel off the top label.
  • You will see 5 holes. The one on the top is for yellow. The two holes on the left are for magenta (red), and the ones on the right are for cyan (blue). Here is a picture:
  • Slowly pour 3-5ml. of each color in the appropriate hole.
  • If ink starts leaking, either from the refill hole or the print head, remove 1-2ml of ink.
  • Gently wipe the contacts on the cartridge.
A few tips:
  • Always make sure that you do not insert air along with the ink, because there will be white streaks on your printouts.
  • Once you have refilled your cartridges, your printer will give you a "low ink" message, which is normal, because the printer can't know that someone has refilled the cartridges. The printer "sees" your cartridges by their serial number, and the ink level will show again once you put in a new cartridge. I suggest you just ignore the message (the estimated ink level is never right anyway), and always look at your printouts- if the colors are faded, or one of the colors is missing, that is a sign that you should refill your cartridges again.
  • Also, if you haven't been printing regularly (at least once a week), the print quality might be poor. You can do a software print head cleaning:
  1. Press the "setup" button on your printer.
  2. Use the arrow keys to select "Tools", then press the ok button.
  3. Select "Clean Print Cartridge", then press ok.
  4. Your printer will then print a test page, which you should examine. If the print quality is good, you're good to go.
  5. If the problem is still there, open the "printer toolbox":
-On your computer, open the Control Panel
-Double click on "Printers and Faxes".
-Right click your printer icon and select "Properties".
-Click on "Printing preferences".
-Click the "Services" tab.
-Then, click on "Service this device" icon.
-The printer toolbox opens.
-On the "Device Services" tab.
-Click on "Clean the print cartridges", then follow the on-screen instructions. (there are three levels of cleaning available). Just bear in mind that software cleaning uses a lot of your ink!
You can also try cleaning the cartridge yourself:
  • Place the clogged nozzles in warm water and soak them until the dried ink begins to flow from the nozzle.
  • After a few minutes of letting the dried ink flow, remove the nozzles from the water and dry it with a soft tissue.
  • If that doesn't help, you might have some air left in your cartridge: try inserting air in the syringe and blow it in one of the refill holes (close the other ones with your fingers). A small amount of ink should be emitted from the nozzles upon injection.
  • Clean the print head and the contacts on your cartridge and pop them back in the printer.
Hope that will help!
Apr 23, 2010 | HP Photosmart 2610 All-In-One InkJet...
I dont know how to clean the leaking cartridges
ink don't leak when the pressure equalizes (inside against outside pressure) ... anyway to make things simple, if you are using a syringe for refilling, **** back a small amont of ink untl leak stops.
Sep 29, 2009 | HP PSC 950 All-In-One InkJet Printer
HP designjet 750c Plus smears and prints a lot of black in everywhere
If you are sure your cartridge is not leaking, ie a refilled unit then it sounds like your waste tank is full. This should be cleaned out when a service is done on the machine. Another problem could be the wiper on the black cartridge is not working. Bottom line if its not the cartridge you will need tech support to help.
Aug 07, 2009 | HP DesignJet 750c plus InkJet Printer
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Canon Printer Picms MP450 Error 6500
They don't like re used cartridges.
I would purchase a new printer as they are not economic to repair.
Feb 27, 2017 | Canon Pixma MP450 All-In-One InkJet...
Printer is not printing black
Remove cartridge and remove the mains from the wall.
Try cleaning the contacts with a cloth dampened WITH WATER, wipe it up with another cloth and let dry.
If your old cartridge is not working again, try with a new one, generally is the cartridge which may become damaged, not the printer... hope !
Dec 31, 2007 | Lexmark X1150 All-In-One InkJet Printer
New black print cartridge not working
I only use refill HP inks. When the cartridge prints gray instead of sharp black it means the ink well is clogged. Yes, that can happen on a new cartridge. Sometimes it happens when they put too much ink in the cartridge, or even heat can make it not work. Also streaking black lines is the problem of the ink not coming out properly. Easiest thing to do is go to a refill station like Cartridge World and have them test it or clean it out. You can also make sure the printer, not the cartridge is clean. Ink builds up an pools. Get some Q-Tips and clean up all that spilled ink. Sometimes in the software it says you can clean the print head, do that too.
Sep 14, 2007 | HP Photosmart 2610 All-In-One InkJet...
Try cleaning the contacts with a q-tip and some rubbing alcohol. Make sure the contacts on the cartridge are clean too. You can buy a new Lexmark Z1300 for $30, and their cartridge prices are not that bad per page any more. So I'm not sure it's worth the hassle and risk of refilling yourself.
Aug 23, 2007 | Lexmark Color JetPrinter 3200 InkJet
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
