Question about Sport & Outdoor - Others
I have a POOLTHERM P-Series heat pump for the swimming pool and the display unit is displaying everything. I cant get it to do anything. Its like its frozen. Do you have any suggestions as to what the problem might be and how I could fix it? I have tried turning it off and on again and given it time to reset but that doesnt do anything.
I have a similar problem. Did you solve yours?
Posted on Oct 21, 2013
2 Suggested Answers
  • 29 Answers
SOURCE: moved a hurl con pump
so put them right
Posted on Sep 16, 2011
My laars series 2 spa heater stays on max heat. i cant lower the heat
if connected to control system maybe relay stuck on or temp sensor showing not up to heat if display you cannot change bad display
Apr 03, 2016 | Pool & Spa
Will a sfs1000/7 work with model 59025 solar heater?
The size of the pool and the size of the filter will play a role in the compatibility of your new swimming pool heat pump. We want to make sure that you have a swimming pool system that would be able to deliver the minimum gallons per minute of water that the new unit would need. We can check compatibility but we would need to know the size of the pool first. Please feel free to email us at splash@backyardocean.com so we can provide further assistance.
Jun 10, 2014 | Backyard Ocean SFS1000/7 Skimmer Pump
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Rheem pool heater no display
check voltage to unit make sure on if voltage check transformer if ok bad display
May 26, 2012 | Rheem 266K to 399K BTU Swimming Pool...
Showing a LP on display. What are the possible problems?
Here is the reason for that problem per the manufaturers web-site
http://www.haywardnet.com/products/Manuals/pdfs/Manual122.pdf
The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to
protect against certain conditions that could be detrimental to compressor life. The switch shuts
the unit down in the event of loss of refrigerant, fan motor failure, evaporator freeze-up and
airflow blockage. The switch automatically resets when the pressure rises to normal operating
pressures. The display will show "LP" if this switch is tripped.
Evaporator Freezing
The low-pressure switch will shut the heat pump down when the evaporator starts to freeze.
When the unit starts to freeze the low-pressure switch will be tripped, causing the display to read
"LP" This will prevent the evaporator from becoming damaged or deformed.
If the air outside the heat pump is not warm enough to produce heat, the system will shut down.
The actual point at which your unit will shut down due to low temperature varies depending on
which model you purchased, current weather conditions, and the amount of sunlight reaching the
heat pump. The shutdown can occur anywhere within a wide range of temperatures, usually 45°F-
55°F. This is not a "fixed" range. We stress that climate conditions, sunlight, and various models
respond quite differently to low ambient temperature. A shutdown occurs because low
temperatures will activate the systems low-pressure safeguard switch (digital thermostats will
display a code "LP".) The unit will start up again when the temperature has raised enough to reset
this switch. Note: Low ambient temperature does not necessarily affect the Chiller models
or the cooling cycle of the heat/cool units.
If this post has helped you, please take the time to vote positively for me on this site. If you need additional help, I can be reached @: adamh@newconceptchem.com
thanks,
adam
Oct 23, 2010 | Hayward Heatpro 81k Btu Swimming Pool Heat...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
May 03, 2009 | Hayward Heatpro 81k Btu Swimming Pool Heat...
Sport & Outdoor - Others Logo
250 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
