Question about Washburn Taurus T14 4-String Electric Bass Guitar
When i play my bass through my amp it is really loud but when i go round my tutors for lessosns he has to turn his amp way up to get any sound at all.
  • Washburn Master
  • 5,603 Answers
His amp probably has lower gain. They vary quite a bit. Also the size of the speaker will affect it a bunch. If his is a tiny practice amp your bass will not generate much noise.
Posted on Mar 18, 2011
  • 1 more comment
  • Joshua Mar 19, 2011
    his has higher wattage and my amp has the option to turn off gain which i almost always do.
  • Fred Yearian Mar 19, 2011
    While wattage is a measure of power output, it is actually unrelated to the voltage gain at the input circuitry. The numbers on gain or volume controls are MEANINGLESS to compare between amplifiers. Some amps like his may have a lower inpout gain hence even though it is higher power, the settings have to be turned up much more.
    If you run a low wattage amp, say 25 or less, don't expect ot get much out of it maximum as it will start to distort when the internal amplifier starts to clip or "flat top". Running the amp at too high a level CAN cause failure and that costs money to repair. A lot of the smaller amps they have boosted the gain for one purpose... to make people think they are louder so they can sell them...
    Also one has to be careful of hearing loss. You should avoid levels above 90 Db... I know several nearly deaf musicians... sad...
  • Joe Patch
    Joe Patch Mar 07, 2013
    Actually, they boost the gains to give distortion for guitar on 1 channel, not so you think you have more.
Can I use my vox vt50 amp to play my bass guitar?
You can use it, just keep the volume low. The amp doesn't care what yu play through it, but the speaker isn't designed for loud bottom end.
Dec 17, 2015 | Bass Music
Playing bar chord at A 5th fret fine move to 7th fret amp gets loud and pops. normal gain at 3 to 4 volume dwn wont do it
Sorry I remember now this is a solid state amplifier,
try electronics spray contact cleaner in the pots of the amp, you will need to unplug and remove the chassis of the amp to do this, there are little notches on the pots, that's where you want to spray, and work the nob back and forth completely, do this to all volume, treb, bass, etc... I know this will fix your problem because I have done this about 100 times servicing amplifiers, the way a solid state circuit works if the pots are dirty the circuit doesn't complete properly causing volume issues, really hope this helps?
Mar 04, 2015 | AMP Music
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
Hello! I've bought a Fender Rumble 75 about 3 months ago and it sounded great really but after some loud playing (About 75% of max volume) it started to buzz at midrange notes, and its gets worse as time...
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
Apr 23, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
This bass squels if you have a bass head and cabinet. i had a 100W amp and it played fine then upgraded to a head/cab. tryed playing it with loud volume, squels. anyway to fix this?
Turn down the treble gain and mid gain... you don't need it for a bass. Prevent the guitar from "hearing" the output of the amp directly. The guitar strings make a good microphone.
Feb 27, 2011 | Epiphone EBO Electric Bass Guitar...
Bass strings are too loud in comparison to treble strings whe played through the amp
Adjust this using the EQ on the amp and to a lesser extent the tone controls on the guitar.
Often people boost the bass way up causing this problem.
Feb 12, 2011 | Epiphone Sheraton II Guitar Electric...
When i play a bit loud (not too much though just when the light blinks red on the hard play) the sirquit closes the amp for two seconds.can you healp me on this ?thank you very much
does your bass have active pick ups?
do the ratings on your amp match the ratings on your speaker?
are you using a pedal?
does your pedal have an output adjustment?
have the ground on your bass checked.
make sure you're using the right kind of cable.
and be sure that the outlet you're using is grounded.
Feb 08, 2011 | Ibanez P500H Promethean Bass Amplifier...
I have a Fender Deluxe Active Jazz Bass thats makes this really really loud buzzing earthy sound. It seems to happen spontaneously, in fits and starts, but particularly if the cable input on the bass is...
This sounds like either a bad guitar cable or a bad jack in the guitar. Possibly your friend is not as qualified to find these intermittent problems as needed? These jacks are really junky and often have riveting of the barrel come undone... especially if the retaining nut is overtightened. The LONG barrel like jacks are notorious for failing. You have all the information you need to solve this problem. First try a different guitar cable... (often they are broken or intermittent at the end where they flex). If that doesn't fix it, replace the jack in the guitar. Also verify that the conductive coating paint within the guitar is grounded. Sometimes the contact to it is destroyed when the volume control shafts or jacks become loose and they depend upon the shaft barrel to ground the paint.
Jan 30, 2011 | Fender Deluxe Active Jazz Bass Electric...
For 100 watts it doesn't seem that loud to me. Could I maybe add more speakers (2x10s)?
Our human perception of loudness can be way off. You should get a soundmeter and compare. There are some pretty good ones on eBay new for about $140.
Adding speakers may NOT increase the sound much as the power will then be split between the speakers.
Nov 02, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Washburn Taurus T14 4-String Electric Bass Guitar Logo
111 people viewed this question
Top Washburn Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Washburn Music Expert? Answer questions, earn points and help others
